Old 05-09-2018, 03:35 PM
sheepy sheepy is offline
So today I replaced the leaking float needle with one from a 2014 model it was 18mm long and old one 15mm thought this was odd as same carb maybe mine had One from an as1? But after a bit of bending I got the float hight to 10mm and while I had the carb apart dropped down to a 40 pilot jet readjusted the air screw now 2 turns out. This has seemed to clean up the whole range no more burble at 3/4 throttle. Still a little rich but a lot better and there is more of a kick to it in the lower revs found that it actually sometimes breaks the traction when going up a technical section. Guess the Suzuki needle will make it more liniear and KTM needle more of a kick?
750ft 15c in sunshine mode
Old 05-10-2018, 04:34 AM
The stock N1EF has a very short straight section, which is also overly rich. It then tapers off quickly. You usually end up with nice off idle and a lean hole in the middle, or a fluffy bottom that snaps to life as it clears out.
Both the Suzuki and Yamaha/Ktm needle has a longer straight section which really helps to dial in the idle and off idle. The Suzuki is probably a bit leaner feeling off idle, and has much less taper through its profile. Steady supply of fuel. The Yamaha/Ktm is a dual taper and you really do feel the transition between the two. It almost leaves a small lean area in the middle/upper rpm where the engine transfers onto the pipe. You end up with a smooth grunty bottom end, and a wild top end on the pipe, with a strong transition between the two.
Old 05-10-2018, 05:53 AM
PFD023 PFD023 is offline
If there was such a position of Sommelier of 2 stroke carb needles Jakobi I think you would own it!
Old 05-10-2018, 10:04 PM
My knowledge is limited as. I only really know the ones I've played with.. Pretty small scope in the big picture I'm sure!!
Old 05-11-2018, 03:28 AM
Bit like. . . Ahh maybe I should behave. I've had some Friday drinks. Let's just say . . Nope probably can't say that here. People might get offended.
Boobs.
Hehehehe. Hooray for boobies.
Jeez, real mature Dave. Am I 13?
Old 05-11-2018, 03:41 AM
Pop quiz.
Who am I, is this me?
Am I one or thirteen?
I've gone cold, hard to deal
Used to stand where I kneel
Old 05-11-2018, 04:36 AM
I don't know why shes leaving or where she's gonna go!
For twenty four years I've been living next door to..
Old 05-11-2018, 04:59 PM
What are you on about? Oh wait. .
Right. That's clever.
Old 05-12-2018, 09:25 AM
Well I got the n3ch needle today so it?s in the bike and what a difference haven?t rode it yet because of there being to many people around but just of the bench it sounds a lot different a lot smoother idle had to wind the idle screw back about 2 turns. Overall it sounds a lot cleaner. Im going out on it tonight so will update this post but it seems like a totally different bike. Current setup
N3ch #3
178 main
40 pilot
1 1/2 air screw
735ft
15.2c
Old 05-15-2018, 12:18 PM
The bike is totally different with this needle pleanty of grunt in the bottom end and nice to ride and then get on the pipe and wow front end up on ever straight going past loads of bike on the pipe in the hare and hound even had someone ask me what I had done to it to make a gasser sing like that I think the should come out the factory like this. Removed the plug and a lovely brown colour I am really impressed with this bike now
Jetting (needles) 2013 gasgas ec 250 nickp Enduro Intake/Carburetion - 2 stroke 7 11-03-2013 02:25 PM
2012 300 jetting bones150 Enduro Intake/Carburetion - 2 stroke 3 05-10-2012 05:56 AM
2012 300 JD jetting kit mblazer11 Enduro Intake/Carburetion - 2 stroke 11 04-17-2012 10:12 PM
Where to buy needles. Other jetting questions. IDAHOSPUD Enduro Intake/Carburetion - 2 stroke 1 11-07-2011 02:08 PM
JD Jetting Spreadsheet - anyone know codes for JD needles ?? DaveH Enduro Intake/Carburetion - 2 stroke 1 02-13-2011 09:40 AM
