#51
I'll def do it. Mine is a late '17 build date, super early haha. Gotta get me a puller first, I think it's a m27 lh
#52
One day I might.
'18 Gasgas XC250 |
#53
Does yours actually start on e-start at all? Mine won't spin cold and just spins over rapidly when hot but no fire.
#54
My CDI is only a single punched one too....
#55
Same puller as on the trials bikes.
Back on a gassy! 2018 EC300! 🤘 Txt 280 07 to make me feel like a gumby again |
#56
If it is M27x1 LH, then it is also the same as most yamahas.
#57
Of the top of my head it is not a left hand thread. It is not the same as the generic Yamaha 2T one. 99% sure it is a 27mm right hand thread. Send me a pm later on and I will check the garage when I get back from work.
Back on a gassy! 2018 EC300! 🤘 Txt 280 07 to make me feel like a gumby again Last edited by Gasser Nate; 08-01-2019 at 11:09 PM. Reason: Stupid question marks again... |
#58
I'm 99% Sure up to 2013 was 27x1.0mm LH puller - kick start only models. I think the e-start with the ring gears required the 27x.10 RH puller, and use a bolt into the crank vs a nut on the crank. 2014 onwards for sure. I'm not certain about the 2011-2013 E start models. |
#59
2011 definitely uses M27x1 LH for the puller and has a nut on the crank end.
2011 EC250E |
#60
2015 on use the 27mm x 1.0mm rh thread puller same as the trials bikes. Early ones use the generic one. Just went out to the garage to confirm. I bought a RFX branded one which is a nice bit of kit.
2018 Starter Fix Thread - Continued. | webmaster | Enduro Electrical & Wiring | 162 | 04-26-2023 02:57 AM |
Eectric starter 2018?s.. | GasgasGP | Enduro Electrical & Wiring | 86 | 11-21-2018 10:03 PM |
2018 Starter Delete | nhgas | Enduro Electrical & Wiring | 1 | 11-10-2017 07:58 PM |
Who can rebuild a FSE 450 starter? Video with problem | olderandyzer | Enduro Engine 4 stroke (including EFI & Exhaust) | 6 | 12-22-2014 04:23 PM |
