Old 04-04-2020, 10:45 AM
5valve 5valve is offline
castrol 5W synthetic, packed in 0.5L, has pretty much the same properties as kayaba01 regarding Cst at 40 and 100 degrees. It is also prescribed oil for SSS and OC suspension fitted on german husqvarnas 310, 449 and 511.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 04-05-2020, 10:31 AM
Zman's Avatar
Zman Zman is offline
It appears to be a fork oil. https://www.castrol.com/en_au/austra...bike-care.html
Castrol Fork Oil 5W 454142
I was not able to find it on the American Castrol web site.
Old 04-05-2020, 09:02 PM
Harry's Avatar
Harry Harry is offline
Thumbs up
This is what I have used in the past. Hi spec synthetic oil at a good price.
Old 04-29-2020, 10:10 AM
Ravenol forkoil light 5W, extremely high viscosity index (300 vs 150 for KYB oil) is even more stable in variety of temp changes and close in CSt to KYB 01 oil. Affordable in EU @ 5.75gbp / quart.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 06-12-2020, 06:15 PM
Gez Gez is offline
I was just reading on teknik motorsport's website that the 2018 and 2019 are specced with with different weight oil. 2018 being 5wt and 2019 being 2.5wt. What am I to make of this? I'm due for a fork rebuild now.
Old 06-13-2020, 01:19 PM
Strange, as both owners manuals (2018 and 2019) state that the same oil (KYB Fork Oil 01M, 5Wt) has to be used
Old 06-13-2020, 06:13 PM
Gez Gez is offline
I was sure it was a typo. I'll be ringing them tomorrow for an overhaul kit and possibly some lighter springs as I cant bottom these forks with the stock springs.
Old 06-13-2020, 08:58 PM
Lighter springs.. You'd be the first there Gez..
You like 50kgs or something?
PS. I don't believe it's ideal to be using all your travel all the time. Might give you a more supple ride, but doesn't give you any leeway in the event of an unexpected. Land to flat from couple meter drop off.. should find the end of the stroke for you!
Old 06-14-2020, 03:25 AM
Gez Gez is offline
I'm 65kg before I gear up. Not much of me for sure. When riding whoops last weekend in the desert, still about 60mm from the fork lug.
Old 06-14-2020, 05:54 PM
I've got 10kgs on you.. might be closer to 15 since I last weighed and I've toyed with the idea of going up a rate. Fully kitted adds quite a few kilos too.
Are you happy with the action? I think stock outer fluid level is around 360ml on these. I used to run 315ml in my old set with heavier springs. Cheap and quick to try!
Jetting alternative wanted Doc Brown Enduro Engine - 2 stroke 10 03-24-2021 06:00 AM
Alternative starter / light switches? SingleTrackMind Enduro Electrical & Wiring 3 05-07-2014 05:19 PM
Alternative lighting for the 2012? myrcrocks Enduro Electrical & Wiring 11 10-18-2012 08:40 PM
Float Bowl Gasket - Alternative Harry Enduro Intake/Carburetion - 2 stroke 4 02-08-2012 01:26 AM
Noz. alternative of N1EG BIS Enduro Intake/Carburetion - 2 stroke 3 07-13-2009 05:25 AM
