Old 05-31-2014, 11:32 PM
acmetrapper62 acmetrapper62 is offline
Default 2001 gasgas 250 xc makes a new sounds
I have a 2001 gas gas 250 xc/ ec model it has 300 low hours on it makin a werid ticking or clacking or some type of sound I never hear before idkk if it the top end needs done or my power valves need cleaned or adjusted. U can notice it at low speeds and idle my air filter was real dirty like bad I changed it and I have this problem there was no dirt in the intake I'm running low octane gas and it suposed to run high octane gas idk if my bearings are bad . I change tranny fluid offen I'm using rotella t6 synthetic oil . Idk I have a race in 2 weeks what should do my self before I take it to someone
Old 06-01-2014, 01:08 AM
Trying to catch a fish? *nibble nibble*
At 300 low hours I think its pretty clear whats needed.. That's assuming everything is stock. If its already had a few pistons and a bottom end, then perhaps it could be the PV, or pipe mounts, etc.
What you do yourself will depend on your mechanical ability and the time you have to spend working on it.
Quick and nasty test for mains bearings, remove the stator cover, grab the flywheel and see if it has any play up and down. Other than that I'd be looking at pulling the cylinder to visually inspect for damage, and then measuring things up. Generally these 250's like a piston and rings every 100hrs (or less if ridden hard). If the same pistons been in for 300hrs bore is very likely worn as well.
Old 06-01-2014, 01:18 AM
I'm pretty sure it's stock it like a rattle sound do u think my reads are bad u think I runs fine it runs like I bought it It was always woods rode not riden hard never used for motocross could I do a comprsetion test what good compression number I'm pretty sure it's comin from the engine
Old 06-01-2014, 09:39 AM
djroggen's Avatar
djroggen djroggen is offline
Pulling the top end off is a small task. Maybe 3 hrs to pull and replace parts and rebuild. Reeds would likely be a problem with starting before they would rattle.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 06-01-2014, 12:18 PM
Banned
300hrs on an original piston and rings is not low. If I were you, I would pull the cylinder off and inspect for wear and if all good with the cylinder put a fresh piston, ring, and gaskets in it.
Old 06-01-2014, 12:21 PM
gassergrant gassergrant is offline
Low octain feul make my bike sound like the piston is trying to get out the block lol, it's power valve clatter, piston slap or detienation from low octain feul
03 ec300
honda cr500 94
Old 06-01-2014, 03:42 PM
300hrs is about 3 pistons worth, and time for a bottom end. Thats with a pretty standard trail warriors maintenance schedule. You're rattle could be one of many things from big end to little end, mains or piston slap. You won't know until you pull down and start looking. I know one thing though, ignoring it probably won't lead to a happy outcome (for you or the engine).
Old 06-01-2014, 04:20 PM
I just put 93 octane gas in it idles better and less piston slap but that chadder is still there but I thing it coming head pipe inside that area i don't know it has less than 300 hrs and it has the orgigal brakes and sprockets I'm thinking around 100 hr or less does gasgas are know for power valve chadder or ticking the bike is not hard to start it has a power valve over sized expansion chamber on it idk if it the o rings in the head pipe because it starting to ooze out exh?ust fluid idk what it is
who makes the GasGas txt 50 boy and ec 50 boy engine roverhybrids Mini Gasser 's Corner 5 02-15-2014 11:00 AM
Rally Raid UK GasGas and other makes Moto7man General Discussions & Announcements 0 06-22-2013 09:37 AM
WP 48mm oil volume??? Dealer sounds crazy! nambo-trev Enduro Suspension 4 10-04-2012 01:06 PM
I hope this movie makes it to the USA einsteingarage General Discussions & Announcements 3 05-09-2011 09:28 PM
Brand New GG 300 Sounds Like It's Going to Self Destruct 2whlrcr Enduro Engine - 2 stroke 24 02-28-2011 07:57 AM
