Old 01-17-2013, 09:25 AM
Steve Croxton Steve Croxton is offline
Default 2012 Parts crossover
Is there one? If so where can I find it?
Thanks
Old 01-17-2013, 01:33 PM
hannesd hannesd is offline
http://www.gasgasrider.org/html/parts_crossover.html
there you go
Old 01-17-2013, 02:19 PM
noobi's Avatar
noobi noobi is offline
What parts are you trying to crossover?
The engine has been the same for a long time.
The chassis and plastic are new 2012, they changed again slightly in 2013.
The e start stuff should crossover to the 2011 e start system.
Suspension changed with the chassis in 2012, linkage changed again(?) in 2013.
Wheels should cross between most years, air filters are 07+ I believe.
Brake pads are off a YZ, I think the numbers are 126 and 326, front and rear respectively.
Old 01-20-2013, 07:34 PM
I'm trying to find out what holeshot/launch device will fit front fork guards.Thanks.
Old 01-20-2013, 10:57 PM
noobi's Avatar
Can you not buy just the button and bracket and fit it to the guard yourself? Allowing you to set the height to what you want.
However, CR fork guards have the same bolt pattern, well at least they have previously. KTM ones will work too apparently but I haven't tested that one.
Old 01-23-2013, 09:00 PM
Yes, but the fork guards on my bike have a ridge in the center right where the button for the launch device would mount, all others(ktm, honda ect.) I've looked at are round and smooth. Does anyone know if there is a brand that has a ridge like the GASGAS?
Thanks
Old 01-23-2013, 11:03 PM
Banned
Polisport has the ridge. It is the same fit as ktm and some crf's
Just bought a pair for a set of zoke 45's.
Old 01-24-2013, 01:17 AM
twowheels's Avatar
The OE GasGas fork guards can be split and removed from the forks without taking the wheel off. The KTMs have the same wrap but not the split (iirc). The Hondas don't have a back and less coverage (again iirc).
Steven Beane #275
afterhourscycle.com
Old 01-24-2013, 10:19 AM
Banned
To find what would fit the forks I went to the Polisport website and compared part numbers, ie GasGas/KTM/CRF all had the same part number. Then just order from the least expensive website and wait.
Sorry Steve I do cheat once in awhile!
Old 01-24-2013, 04:40 PM
robszombie's Avatar
robszombie robszombie is offline
Still no luck sourcing a 2012 aftermarket brake pedal. I hope someone builds one soon. If i break/bend this third one I'll have to go back to the 2011 model!!!!!
Another Parts Crossover Question carlg Enduro Chassis & Body 1 11-28-2010 11:37 PM
EC200 parts crossover rupecopp Enduro Other... 7 10-20-2008 08:27 PM
4-stroke parts crossover Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 4 11-05-2007 01:07 PM
MC65 parts crossover? bergerhag General Discussions & Announcements 5 10-07-2007 09:16 AM
Parts Crossover idea Phattaff Suggestion Box 3 08-21-2006 05:43 PM
