Old 03-09-2012, 10:33 PM
Banned
Haven't read whole thread, just be aware to melt nylock nut before trying to remove that nut that holds the wire linkage in pic. They are only m4 & like to shear off, that is a pain but repairable. I forgot last time.
No shims, just loosen & readjust lever in cases. Becomes obvious when you do it but the thread help with pics.
X2 on heating up the nylock. Snapped my bolt off and had to weld a new threaded end on it. Not a pain if you have a welder.
Old 03-09-2012, 11:07 PM
Originally Posted by Gasserguy250 View Post
I can move the rod with my hand From closed to open very easy, does this mean I have probs? If so whats gone wrong and how can I sort this? Manythanks....
No. Normal.
By pulling on the rod, you are spreading the governer ramps apart.
Old 03-10-2012, 01:16 AM
waycrazy waycrazy is offline
Wish I knew that 3 weeks ago.....
Lucky for me a machinist buddy owed me a favor and made me a knew one. Saved me about $35
03 EC300
The pig...04 XR650L
01 380sx
Old 03-19-2012, 08:44 PM
Leo's Avatar
Leo Leo is offline
Power Valve assembly
http://youtu.be/5Pojit9nvEQ
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 10-08-2012, 11:40 AM
skraMnoR
Guest
Posts: n/a
I had been experiencing poor low end performance on my 2011 Gas Gas EC250. I jetted the bike but the performance continued to be bad and actually degrade. Along with the degradation of low RPM power I noticed an increase in a rattling sound. The sound occurred at idle only and was not the chain. I ruled out the clutch as the sound was present with or without the clutch engaged. I decided to investigate the Power Valve system. Below is what I did to fix the issue. I am not a Gas Gas Mechanic. Please consult your manual or a qualified mechanic. I am not responsible. I am merely offering what I did to fix my issue. Your mileage may vary. (Some pictures are mine and some from the internet).
1. REMOVE EXHAUST EXPANSION CHAMBER
? Mine had two mounting screws on the pipe connecting to frame via brackets
? Also remove the 2 springs holding the pipe on to the front of the cylinder.
2. DRAIN COOLANT
? Open the drain screw on the right hand case.
? Safely discard and use fresh for reassembly.
3. DISCONNECT COOLANT HOSE
4. DRAIN OIL
? This is not necessary if you choose to lay your bike over on its side
? I choose to drain my oil and do the work on the kick stand. (I change oil often anyway)
5. REMOVE KICK STARTER
? There is a small bolt on the face side.
? Make note of the orientation of the lever so you can re assemble the same way.
6. REMOVE THE SIDE CASE
? You will need to remove 2 long screws from clutch cover as they go all the way through
? You may need to disconnect brake pedal from rod as well.
? I removed the small case over the coolant impeller and the impeller also. This may not be necessary.
? Take your time here. You do not want to pry off the side case with a screw driver and mess up the case. You may end up with sealing issues later on. There are 2 guide pins that force you to take the case off straight out.
7. ASSESS THE POWER VALVE
? The actuator plate should be solid against the stop bolt while the bike is idle.
? Also note the actuator connecting rod for clearance against the case opening at the bottom of the power valve chamber
? DO NOT move the power valve assembly through its full range of motion. The governor has 6 ball bearings that are held in place by the power valve spring applying back pressure. You run the risk of creating a gap in the system and having all the ball bearings fall out.
8. ADJUST IF NECCESARY
? If your actuator place is not ?against the stop? at idle you need to adjust. This means that that the power valve ?flapper? is not fully closed when it should be. The results in low RPM power.
? Take care to understand how it all connects before you loosen anything.
1. Loosen the set screw until it no longer holds the shaft in position. Note that everything can easily fall apart at this point. So use both hands and take your time.
2. Rotate the entire bell crank, rod and actuator plate until the plate is against the stop and re tighten the set screw. If you cannot rotate far enough for the plate to hit the stop, examine the rod and see if it is binding on the case opening.
? If the rod is binding against the case, you will need to disconnect the rod and do some careful bending.
1. There are 2 nuts that need to be removed. One on the actuator assembly and one on the end of the bell crank. Take your time and do NOT use air or electric tools. The post on the actuator plate can be fragile. Some people will slightly heat up the nylon inside the nut to make it easier to loosen.
2. Once the rod and bell crank are out you can make your bends. Be very patient and make very small bends. Test the fit after each slight bend until you have it to where the rod never touches the sides at all throughout the full range of motion and the actuator plate rests against the stop. NOTE: Being that the rod and bell crank are not connected to the main power valve governor, there is no risk of the ball bearings falling out
9. PREPARE FOR REASSEMBLY
? Clean off all the old gasket material
? Make sure there is no coolant in the engine case
? Add the case gasket to the case and rest on the two guide pins
? Slowly push the case back on. Note that you must put the case on very straight. There is a low tolerance on this fit. Do not try to force it. Take your time and it will seat.
? Replace bolts and torque to spec a little at a time. Use the attached picture to help determine which bots go where. Image was obtained from Gas Gas Riders Forum.
? Reconnect exhaust, coolant hose and brake lever
? Add oil and coolant to manual specs.
Here is a PDF of this all.
http://skramnor.com/FILES/pixforpost...pvtutorial.pdf
Old 10-08-2012, 03:12 PM
timlh's Avatar
timlh timlh is offline
Default Be careful if you lay the bike on its side to remove cover
Not sure if this applies to all years but it does apply to my 01 XC 300. When laying the bike on its side to remove clutch cover check. First check to make sure the shifter is not resting on the ground. If it is put something under the handle bar end to make sure the shifter is not touching the ground. Otherwise the case wouldn't go back on because the shifter shaft gets pushed out on the clutch side. Depending on your bar width this may not be an issue. I use the Burleson bend Moose oversize bars as they were the narrowest bars I could find without cutting them down.
Sorry didn't mean to hijack the thread just thought this was worth mentioning.
skraMnoR, Great job with the documentation and pictures.
Old 12-02-2012, 12:04 AM
thumperflipper thumperflipper is offline
Default a couple of videos of powervalve mechanism
My first post, so hope the links work. Thanks to everyone for your input on this site.
Powervalve Governor assy:
http://www.youtube.com/watch?v=PYVHI...5&feature=plcp
Powervalve mechanism at work:
http://www.youtube.com/watch?v=hmz9c...6&feature=plcp
Old 12-02-2012, 12:42 AM
stabak's Avatar
stabak stabak is offline
great vids flipper, thank you
Old 01-02-2013, 09:28 PM
knobbyboy knobbyboy is offline
My bike has developed a rattle in the last couple of months (06 EC300) and i am pretty sure its due for a top end job. I replaced the pipe o-rings to try and stop the rattle, didn't help. I have gone all over the bike with it running trying to find something loose- pipe, skid plate, etc.- can't find anything. Some say the new top end will get rid of the rattle. I came across this thread and have read it through twice and went out in the garage several times to look at the parts on my bike. My actuator plate is fully against the allen head stop bolt. I can roll it off the stop bolt without much force (I also read I should not be doing that, hope nothing fell out, i did not hear anything drop in there- read that part later on...). If it were off the stop bolt this would be a clear cut solution but as it is I am not sure its needs adjustment, $30 something in side case gaskets to open it up and make sure. I can reach in the exhaust opening and in any position the pv itself has some slight wiggle to it. I just can't sense much "slackness" in the actuator. I can't run the bike to see what it does running because its partly torn down getting ready for a top end. The arm is centered in the hole, no problem with that, its is not hitting the sides anyplace. Not sure what to do. I'll try to put up a pic of the mech at rest as it sits right now... Any advice?
Old 01-02-2013, 09:46 PM
...check out the pic and let me know what you think. It looks fine to me. But then what is that sound? Can the parts of the actual PV wear out? Guess i'll know more when i tear it down. Fork and shock already out to be rebuilt. And as far as low end power loss can't notice much there apart from likely needs rings anyway.
Low down / tickover issue HELP stevehipkiss Enduro Intake/Carburetion - 2 stroke 9 02-14-2011 09:03 AM
jetting - idle issue. stainlesscycle Enduro Intake/Carburetion - 2 stroke 7 12-30-2009 02:47 AM
clutch issue boostedte37 General Discussions & Announcements 2 11-09-2009 06:58 PM
ec 400 gearbox issue Paul Somerville Enduro Engine 4 stroke (including EFI & Exhaust) 3 09-05-2009 10:17 AM
PowerValve Issue- Take A look at this Picture alexpp Enduro Engine - 2 stroke 13 04-12-2009 12:13 AM
