Old 11-01-2018, 10:42 PM
Saddleback51 Saddleback51 is offline
My 2019 EC 300 runs perfect stock out of the box at @ 500?...must be the changes made from 18 to 19...any thoughts?
Old 11-02-2018, 02:02 AM
Gas Gas have delivered their engines of varying capacities, with different model keihin carbs across the years.. all using the one same needle.
You can decide based off that how close their stock jetting probably is.
Granted the bikes have always ran alright... usually a bit fat off the bottom which can load up a bit in tight riding, with a wild mid range snap.. and very less than average fuel consumption. Definite room for improvement.
The N1E series is also what KTM uses in their SX models. They use the NR8/N3E etc in their exc models. And many riders prefer the Suzuki range of needles in them too.
Similar story with Beta...
Old 11-02-2018, 09:37 PM
Fieds83 Fieds83 is offline
Today a made installed a half clip shim.
NEDW clip 2 plus shim
40 pilot
Air screw 1 turn
175 main
Including the shim makes it the same as NECW clip 3 i believe.
Improved snap off the bottom, eliminated the flat spot. A bit of burble came back at cruising speeds.
Might give clip 2 and the 45 pilot a go.
Old 11-03-2018, 08:11 AM
dzhitshard dzhitshard is offline
can anyone confirm for me the order of richness of these 3 needles?
NEDW
NECJ
N3CH
I have the N3CH on it's bottom richest clip position and at 60f temp at 1000'ASL it was good. At 40f it has a lean bog off idle and I can't make it richer with the clip. MooseRun is tomorrow and I have the 2 other needles but very little window window to test.
Old 11-03-2018, 09:06 AM
To clarify I'm looking for which of the top 2 would come closest to an N3EJ. Im missing the connection between N"3"XX and N"C"XX needles
Old 11-05-2018, 04:28 AM
Wimpy525 Wimpy525 is offline
Default Thanks to Jacob and Doc Brown
So rode this weekend with the changes made by Jacob and Doc Brown. So here I am with a 180 main, 42 pilot and an NEDW needle. Idle screw was too far in made that adjustment and tired it out around the house seemed good. Did a ride this weekend and bike ran wheel. A bit of spoog around the exhaust, just enough to tell me it made the trip. I did experience a bit of a hanging idle after lugging the bike for very long sections but it cleared up after a few seconds of idling.
I am going to tear the bike down at this point check the squish and figure out if I am going to cut the head or buy the RK tech head.
So thanks for the help guys.
Old 11-07-2018, 10:06 AM
Hi Wimpy525, good to see that you could improve the running of your beast. They tend to spooge quite a bit, but that's pretty normal.
If the lean hang is only for a second or two and the bike is running fine otherwise I would not touch the carb. If its definitely more than two seconds you could try to close the air screw in 1/8 steps but not more than one quarter turn. Normally that helps to cure it and one quarter is sure within the limits.
Looking forward to reading your experiences and thoughts if you do the head cut.
Old 11-07-2018, 02:55 PM
I've got 42 NEDW#2 175 with a cut head.. getting very excited too see how the 18 model runs compared to my previous engines.
Old 11-07-2018, 04:48 PM
You should be! I think the motor is great good and luggable. What really stands out to me is the suspension, I had my zokes and the ohlins shock set up really well on my 13. Well with the KYB I am amazed at how hard and fast I can hit stuff. Rode sand all last weekend and I am not a sand rider and felt pretty comfortable with just a few more clicks of compression on each end.
This bike is just awesome, so awesome in fact I am going to race the entire local enduro series next year all 17 events. This is something I have not done since 13 so that how stoked I am about this bike.
Old 12-06-2018, 05:29 PM
symon260z symon260z is offline
Thumbs up Thank you
I wanted to say thank you for all the people that have posted on this thread. My 2019 EC300 ran terribly at anything below 75% throttle. I fitted a NEDW needle 2nd position from the top, a 40 Pilot Jet and I have since found that the Air screw at about 2 turns is about right.
Now my GasGas runs beautifully all the way through the rev range, now I can concentrate on learning to ride the bike.
Thanks again
Revised Jetting Specs NEDW Jakobi Enduro Intake/Carburetion - 2 stroke 197 09-19-2014 08:17 AM
'06 EC300 stock handlebar specs? brider Enduro Chassis & Body 0 09-16-2013 03:08 PM
What is the stock 200 needle and jetting specs shaheeb Enduro Intake/Carburetion - 2 stroke 3 03-24-2012 10:56 PM
2010 EC300 Factory Jetting Specs - WTF? JP4 Enduro Intake/Carburetion - 2 stroke 197 07-04-2011 11:03 AM
