Old 09-13-2015, 12:54 PM
krazy's Avatar
krazy krazy is offline
Default 2001 ec300 power valve free play
Hi,
Per the video the actuator stays open if i slowly move the plate, but if i move it sharply and let go it does snap shut. Is that normal behaviour?
Would i use the right screw near my finger to adjust the arm up further?
I also want it to open sooner in general, so which of the shims should i remove, closest to engine or furthest? I am assuming the bushing things on either side of the pin are the shims.
https://youtu.be/4QrYbH3m6Bo
2001 EC300, mild porting and head work, DEP silencer, EC200 CDI
Old 09-26-2015, 04:26 AM
I believe I used the allen key pointing towards the camera to adjust mine. Needs to be shut firmly otherwise the valve will flutter.
2016 RM-Z450
'14 EC300 Power valve not opening poelinca Enduro Engine - 2 stroke 9 09-17-2015 02:58 PM
Throttle free play 95jersey Enduro Chassis & Body 6 06-25-2015 05:07 PM
Slight free play in forks 400_racer Enduro Suspension 9 06-27-2012 09:38 AM
Free Play in Sachs Forks? 2whlrcr Enduro Suspension 10 03-07-2011 10:45 PM
2011 ec 300 Throttle Cable doesn't have any free play... rgranger General Discussions & Announcements 7 01-29-2011 10:03 PM
