Old 09-08-2014, 05:02 AM
V1T0 V1T0 is offline
Default FSE 450 rebuild, DR-Z parts?
Hi! I'm rebuilding my 450 engine. I have to change these parts:
OIL PUMP BODY
OIL PUMP ROTOR
RETRIEVABLE PUMP RING
RETURN OIL ROTOR
OIL PUMP COVER
CENTRAL CRANKCASE GASKET
CLUTCH COVER GASKET
DISCS COVER GASKET
IGNITION COVER GASKET
CAM SHAFT DRIVE CHAIN
CYLINDER GASKET
CYLINDER HEAD GASKET
I also need bearings, piston, cylinder regeneration, cam regeneration, clutch discs and tappets.
And I have a few questions.
Where should I order parts? My mechanic told me that he can buy parts for me and it will be 1500 euro which is lots of money.
I heared that cilinder head is exactly the same as Suzuki DR-Z 400, is it true? OEM tappets would be 200 euro, tappets from DR-Z are much cheaper.
And the bearings. Can I use others than OEM? Like SKF, KOYO or something? What's the difference? I need 6306C3 and 6303C3.
Thanks.
Old 09-16-2014, 07:40 AM
MercyFlush MercyFlush is offline
I can say that drz cam chain fits 100% on my FSE450 from 2003. I replaced my tappets with OEM but I'm 98% sure they were the same size as my DRZ's (I own one of those too). Maybe look at getting parts form somewhere else because I only paid $80 for each tappet and DRZ ones were $112 each I bought from Scotties Dirt Bike Spares in Melbourne Vic Australia.
Old 09-16-2014, 10:29 PM
300ECR 300ECR is offline
I had a head rebuilt by scottys a year or so back and from memory it was only $200. That was for FSR 450 08
Old 10-03-2014, 05:31 AM
GooseMan GooseMan is offline
I just got a new cylinder with piston and rings, both clutch gaskets, head gaskets tappet cover seal etc all for $500 to $600 from the guys at motocross center, try them they were very helpful and deliver fast.
Old 06-05-2015, 01:02 AM
Tafka Tafka is offline
Does anyone know if i can replace head gasket with some other than original GasGas....bastards want 50 euros (55-60 dollars) for that gasket...
Old 06-30-2015, 01:47 PM
Loki Loki is offline
Not to hijack the thread but I'm wondering whether the sensors and injector might cross over from Suzuki as well
Old 08-16-2015, 02:08 PM
mike989 mike989 is offline
Default valve stem seals
Does anyone know of another brand of valve stem seals that will cross over to GasGas?
Due to the GasGas parts shortage I have run out of dealers to check.
My street legal 07 450 with 1530 miles on the clock has started to smoke a bit sitting at red lights. I did a leak down test, and it was well within spec, it still runs strong. I suspect the seals.
04EC300
04Wild450
07FSR450
Old 08-17-2015, 03:25 AM
Damn, my bike is smoking too (quite a lot). I'm going to order some over here in Aus, but I'll take the ones out of my bike and measure them and let you know what they fit. I'm pretty certain they will be exactly the same as DRZ ones, because essentially everything DRZ fits the top end (Buckets, shims etc.). Mines a 2003 btw, but I think it'll be the same. At the worst you can take yours out and compare measurements with me.
Old 09-03-2015, 10:22 PM
If you could pass that info along when you get to it, that would be a huge help.
Thanks.
Mike.
04EC300
04Wild450
07FSR450
Old 11-11-2017, 02:12 PM
Adam_redneck Adam_redneck is offline
As far as I know an entire top end from a DRZ will fit but you will need the high compression piston or you will lose some power!
GG FSE 450 crank shaft and other parts [rebuild] V1T0 Enduro Engine 4 stroke (including EFI & Exhaust) 8 10-27-2018 11:43 PM
Top end rebuild forgiven Enduro Engine - 2 stroke 9 12-05-2013 11:01 AM
05 rebuild brains Enduro Suspension 2 07-22-2008 08:54 AM
Rebuild steve Enduro Engine - 2 stroke 8 01-13-2008 03:06 PM
