Old 04-14-2020, 07:40 AM
Gassi01 Gassi01 is offline
Default Harder spring for Marzocchi 45mm
Hi,
have a problem to get harder springs for a EC125 -10.
The spring is 470mm x 40,6mm.
Is a standard spring for now. I think it is for 75kg.
We need springs for 85kg person plus gear, so 95kg.
Have some one a idee where I can get this?
Live in Sweden.
Thanks / Michel
Old 04-14-2020, 12:35 PM
SS109 SS109 is online now
BetaUSA's online web shop has springs listed for the Shiver 45's. https://shop.betausa.com/p/fork-spring-45mm-marzocchi I'm sure someone on here will be able to help with what spring rate you need.
Old 04-14-2020, 02:38 PM
rvktm rvktm is offline
k tech uk or s tech Germany or ebay
Old 04-14-2020, 05:14 PM
I found some s tech in Germany
Thanks for your inputs. Michel
Old 04-16-2020, 03:22 PM
i looked on ebay 105 e
Old 04-16-2020, 10:53 PM
Jim_C Jim_C is offline
Originally Posted by Gassi01 View Post
Hi,
Live in Sweden.
Thanks / Michel
Are you aware of the Progressive Floating Piston (PFP) in the top of the forks? The "Zokes" come pretty stiff stock. If you turn the PFP in a few turns and turn in your compression clickers some you might like the feel before re springing.
Just a thought....
Old 04-17-2020, 01:09 AM
Anders Anders is offline
Just a thought....
That is not the case for the 45mm Marzocchi, only the 48mm PFP fork on later bikes
Old 05-06-2021, 03:01 PM
maxfli11 maxfli11 is offline
You'll note that link only references the 2010-2011 forks.
Old 05-06-2021, 05:28 PM
Yeah, 2010-2011 Beta RR and RS models. They will fit any 45mm Shiver fork.
Marzocchi 45mm settings Russmann Enduro Suspension 7 06-01-2020 09:01 AM
Marzocchi 45mm Forks mcnut Parts 9 01-12-2016 10:23 AM
marzocchi 45mm shiver johall865 Enduro Suspension 0 12-28-2014 06:55 PM
ec300 marzocchi 45mm kingsizerizla Enduro Suspension 7 01-30-2014 10:51 AM
Marzocchi 45mm bushes iancp5 Enduro Suspension 0 02-25-2008 02:49 AM
