Old 09-22-2011, 12:54 AM
Jaluka Jaluka is offline
Default '06 300 Speedo problems. Should turning of front wheel switch unit on?
Hello all
Please could you help, I have bought a 2nd hand ec300 2006 and noticed that when I start the bike, the instrument panel comes on. However, with the bike switched off and on the stand, if I rotate the front wheel the instrument display remains off. (on my KTM the unit would switch on if the wheel was rotated)
It also appears that the speedo is not showing a speed reading when I ride so I assume that I may have a problem with the magnetic sensor or it's wire not sending a signal to the unit. (the other functions seem fine)
Please could someone confirm if the unit should switch on simply by rotating the wheel or pushing the bike when not running?
Many thanks for any help
Matt
Old 09-22-2011, 07:41 AM
eff's Avatar
eff eff is offline
Is it the trail tech unit? If so yes. Maybe cable? Did it do this after the bike was soaked? Mine doesn't like to work when wet.
2004 GasGas DE250
Old 09-22-2011, 06:48 PM
Thanks for the reply eff
No it is the Acewell unit.
I have tested it when dry, still not turning on with wheel rotation......
Any riders out there with the same unit?
thanks
Old 09-23-2011, 01:59 PM
wasp4banger wasp4banger is offline
Not sure what the make of mine is, but it only powers up from the engine running.
The wiring on the back of my unit had the insulation break on it, so I replaced the wiring into the unit. Worth checking the wiring out.
Gas Gas EC 300 '06
BMW F650
Old 09-25-2011, 01:04 AM
thanks mate will haul out the multimeter and test the wires
cheers all
spring affects on turning..... dank Enduro Suspension 17 08-20-2010 07:07 PM
CLock/Speedo unit not working Chilli Enduro Electrical & Wiring 16 04-27-2009 03:33 PM
Will anything other than a GG front wheel fit a GG? cal_tony Enduro Chassis & Body 7 11-08-2008 09:21 AM
