Old 01-11-2013, 01:16 PM
husley's Avatar
husley husley is offline
Bronze Level Site Supporter
Default 2010 300 90 hrs. Rings or Piston also?
2010 90 fairly mellow hours. Tearing the bike down and figured I will give the top-end some love.
Replace Piston and Rings or just the Rings?
Thanks
J
2015 KTM 450 XCW
2014 350 XCF Wife's
2009 200 ec. Loving it
2007 Beta Rev 3 270
2007 KTM 200 XC Wife's
Public Lands belong to the Public
Old 01-11-2013, 02:14 PM
Brian VT Brian VT is offline
I did both after a lot more hours than that. Like you, just "for love".
I already had the parts before tear down and it turned out that the piston spec'd fine.
I had a new one, so I installed it. Cheap insurance, I figured.
Old 01-11-2013, 04:45 PM
I always do the piston and rings together. Its not that much more $$ or time wise, considering you have to pull all the gaskets, drop coolant, blah blah blah. In the end cheap insurance.
In my 2010 300 the piston was slappin around at 75hrs although the ring gap only measured in around 0.5mm
I'd also suggest throwing a fresh little end bearing in too. Again, just for cheap insurance.
Old 01-12-2013, 10:59 AM
husley's Avatar
Default Cool
Suggestions on a top end kit? Would be nice to order all the parts in one kit.
Wossner makes a kit I believe.
Thoughts?
2015 KTM 450 XCW
2014 350 XCF Wife's
2007 Beta Rev 3 270
Old 01-12-2013, 04:29 PM
noobi's Avatar
noobi noobi is offline
Thoughts?
There will be plenty of different opinions on which piston kit is the best, but at the moment I've been through 4 Wossner kits on 3 different bikes and had no problems. I will be using them again. They also appear to be fairly well priced.
A German made forged piston, what more could you ask for.
Then you just need a base gasket or 2, as pulling off the head isn't necessary.
Old 01-12-2013, 04:57 PM
Agree with Noobs. I have run both the stock Vertex and Wossner kits. I was really impressed with the wossner. Good quality at the right price point. Freely available from several sources and generally comes with piston, rings, clips, and pin. Throw in a couple base gaskets, little end bearing and you're done.
If you've got a few hours on the bike I'd probably do the head o-rings as a precaution. Also like to have spare water jacket gasket, pv gaskets, exh o rings, and flywheel gasket on hand just incase anything gets torn during pulldown or needs replacing. A smear of grease or gasket goop makes for easy removal next time and better odds of re-using them. Obviously don't bother trying to reuse the base gaskets or head orings (if removed).
Ebay has several kits
Standard ec 200 piston rings davidlenton Enduro Engine - 2 stroke 3 01-11-2013 10:58 AM
Piston & rings Questions biggstr6 Enduro Engine - 2 stroke 5 08-10-2011 04:36 AM
piston rings thenutt Enduro Engine - 2 stroke 3 06-10-2009 06:16 PM
Vertex Piston rings q FFRDave Enduro Engine - 2 stroke 21 12-10-2007 04:51 AM
Piston and rings EC 300 brains Enduro Engine - 2 stroke 1 08-22-2007 12:11 AM
