Old 06-06-2013, 01:28 PM
bazzagas bazzagas is offline
I use Maxima MTL Ultra Light 75wt in mine, smooth shift and no squeal from the clutch no matter how much use it gets. I put in 900ml when I do an oil change.
Old 06-06-2013, 04:31 PM
Wheelieman69's Avatar
Wheelieman69 Wheelieman69 is offline
900 here
Wheelieman
Old 06-06-2013, 05:29 PM
djroggen's Avatar
djroggen djroggen is offline
2-Strokes take gearbox oil?
Spectro Clutch Saver, because the name makes me feel like it saves my clutch!
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 01-29-2014, 11:23 AM
sevenfourate's Avatar
sevenfourate sevenfourate is offline
I changed my 2006 EC gearbox oil to a Rock 'Light' oil just after i first got it. Ive had no clutch problems at all, apart from some drag (Like all GG's suffer from what i read), so all good there and ive just purchased a couple more litres.
Some people suggested 900ml - some said to just pour the whole 1 litre in...... Which is rightly or wrongly what i did !
Ive done a couple, or perhaps three: 100 mile rides since then (Approx 15 hours riding) maximum. Should i be changing again about now, or whats the 'normal' frequency ??????
Also - has anyone experimented with LESS than 900ml of gearbox oil to try to reduce clutch drag ??? [I gather this is a very common trick with GG Trials bikes].
Cheers.
Regards Shuv - 2006 EC 250
Old 01-29-2014, 11:52 AM
AZRickD AZRickD is offline
2011 EC250 with Rekluse -- 1,000 ml of Walmart ATF.
Old 01-29-2014, 05:05 PM
Zman's Avatar
Zman Zman is offline
I have had very good luck with using half ATF and half synthetic 5w-40 diesel engine oil. I like its performance better than many cycle trans oils (great clutch action without the drag) and it is considerably less expensive than cycle trans oil.
Old 01-29-2014, 11:59 PM
Rick's Avatar
Rick Rick is offline
900.ml is what the manual calls for.......in my 99 EC 200. Motul Transoil works for me........I have moved on to Rock Oil as well.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 01-30-2014, 10:43 AM
j_franich j_franich is offline
Originally Posted by '11EC300 View Post
http://www.gasgasrider.org/html/gear...valuation.html
I use Amsoil 0W40 and am happy with it.
I've used the Amsoil 0w40 in my 200 and 250. With and w/o Rekluse.....no squeal, no chatter, shifts great.
'05 EC200
Old 05-30-2014, 07:34 AM
kyton's Avatar
kyton kyton is offline
would any of the below work. 1L is half the price of the belray gear saver 80w
Caltex GEAR OIl EP - thuban gls sae 80w-90 api gl-5 , mt-1
castrol syntrans multivehicle 75w-90 apgl4
castrol axle epx 80w90 api gl5
Old 05-30-2014, 11:01 PM
sweeper sweeper is offline
Banned
That will depend on how hard you ride the bike.The heat you build in the gear box and the wear on the fiber is your gauge.
People in general just dont ride as hard as they used too.This has more to do with availability of riding areas and proximity to them.Also there is a different mentality these days,where looks seem to trump the actually riding.So these intervals will vary.
Two schools of thought also.Some riders prefer to use more expensive gear box oils and change it out less often.Others go the cheaper route,relatively speaking of course this is not a good place to cheap out,and change the gear box oil more frequently.Myself,.and most I ride with like to change the gear box oil often and dont use that fancy crap.In the end it comes down to viscosity at max operating temps and the breakdown of the oil you use combined with friction wear and other contaminants.
It should always look clean,feel slick and smell right,yep the old pull it off the dipstick with your index finger and thumb and rub them together and give it a smell style.Unless of course you have a fancy hour meter which really wont tell you much since 6 hours from rider A could be equal to 20 hours from rider B.The condition of the oil itself, how the clutch feels when you are hammering it down and how long the clutch lasts will tell you the most.Not just the friction plates but the entire clutch will tell the story.
gearbox question mikevancapel Enduro Engine - 2 stroke 2 01-01-2012 09:57 PM
Wild 300 Gearbox problems case-racing Other GasGas Bikes/Quads 1 09-17-2009 01:51 PM
ec 400 gearbox issue Paul Somerville Enduro Engine 4 stroke (including EFI & Exhaust) 3 09-05-2009 10:17 AM
Milky gearbox oil juzzasmith Enduro Engine - 2 stroke 10 03-12-2007 05:40 PM
EC250 '98 gearbox questions Leon_gasgas Enduro Engine - 2 stroke 16 09-04-2006 04:50 AM
