Clutch lever feels notchy only when engine is running
My 2000 XC300 clutch lever feels notchy when pulling in the lever while the engine is running. I lubed the lever and it did not help. It fleels butter smooth when the engine is off. It has the original clutch and it works great other than the lever feel recently. It never makes noises or acts oddly. I pulled it apart and there was minor wear on the basket that cleaned up with a few strokes of a flat file. I had a newer hub so I swapped that in as the original had a little wear from the teeth of the steels. Amazingly the fibers and steels were all still within specs. I did not check the push rod but wish I did to make sure it was not bent and touching the gear shaft inner bore.
I have not ridden it since I cleaned up the basket, because we just got more snow in Chicago and it is flipping cold here!!!!! Has anyone else experience this issue before? Last edited by Zman; 02-16-2015 at 07:02 AM. |
My money is on the basket. My Honda 450 X got like that all the time
02 EC 200 03 MC 250 88 VT 800 01 TXT 280 |
The clutch lever on my bike was binding at about half way and what I found out was that when I adjusted the lever to suit standing with the pro taper bars, it was catching on the handlebar light switch mechanism. Luckily a simple fix.
Good point but in my case the lever is free to move without interference.
I think that the basket clean up and different hub took care of it.
aid ! |
Clutch Lever Feels Notchy | Zman | Enduro Engine - 2 stroke | 3 | 11-10-2014 06:14 PM |
Whats a 2003-04 good running 300 engine worth? | sweeper | Parts | 13 | 10-29-2014 08:30 AM |
Clutch lever doesnt release clutch as soon as motor starts | cal_tony | Enduro Engine 4 stroke (including EFI & Exhaust) | 5 | 05-19-2012 08:59 AM |
Anyone Running Engine Ice? | lordfeyr | Enduro Other... | 14 | 06-25-2011 10:16 PM |
