Old 09-23-2019, 06:47 PM
TGM_OFFROAD TGM_OFFROAD is offline
My 2018 I just got about 2 weeks ago just sheared the flywheel key. I have been having trouble with the e start since I first got it and replaced the ignition cover and starter motor that was burned out. Today it felt like it was binding still and then poof it started no problem. Then when trying again the bike backfired and I heard a clunk and the bendix sounded like it was not actuating. I pulled off the ignition cover and noticed the flywheel felt loose and the flywheel bolt was finger tight and backed out a couple of turns. I pulled the bolt out and the flywheel slid off no problem and I noticed the key was sheared right off.
I heard someone get their flywheel replaced proactively as a recall previously, is that related to this? I am just going to order a new key but this is kind of lame.
Note: The bike is fairly new with only an estimated 20-25 hours on it.
Old 09-24-2019, 04:53 AM
Gasser Nate's Avatar
It has been previously mentioned before that the early 2018s needed the flywheel bolt torque checked for this reason. Mine was drowned in loctite but it had set before being torqued all the way. If it is starting fine with that flywheel throw a new key in it and torque to spec with loctite.
Old 09-24-2019, 11:21 AM
Yes I was seeing that, I wish I saw that 2 days ago though.
2019 ec300 fuel mrquick Enduro Engine - 2 stroke 76 09-29-2021 01:58 AM
2019 EC300 Review Jacob 'Berg General Discussions & Announcements 2 06-01-2019 12:22 PM
2019 EC300 Engine Vibration RudolfHucker Enduro Engine - 2 stroke 30 02-27-2019 09:49 PM
2019 ec300 Saddleback51 Enduro Intake/Carburetion - 2 stroke 0 11-08-2018 12:26 PM
main bearing failure right side 2006 ec300, rebuild tips needed. hillbilly Enduro Engine - 2 stroke 11 03-16-2012 04:42 PM
