#51
the problem
The upper ring broke and wrapped around the head of the piston, causing grooving into the cylinder. Everything looked good every where else.
#52
One more questions
Is it odd to have 8 to 12 ounces of oil pour out of your pipe when you remove it. After disassembling the bike to rebuild the engine, i was cleaning parts and when i got to the pipe a good 8 to 12 ounces of oil had been sitting in the bend of the pipe for who knows how long.
#53
Wow. It is what it is obviously, but that was a strange set of circumstances. Running one minute and then not restarting.
#54
The bright side of it is i am now rebuilding the entire bike. Is an 03 so it wont hurt to do the whole thing. I have decided to upgrade some parts as well. I love tax season. I am definitely going to upgrade the stock crappy magura hydraulic master cylinder clutch, mine operated as hard as a cable clutch. |
#55
So, yes, that is odd.
Phil (New bike pending...) |
#56
Thanks
Another Clue.....Good Lord
So, I got around to unpacking the silencer today and this was the result below. The packing was dripping in oil and when i removed the old packing the perforated inner tube is completely clogged with carbon, not just covered in oil but clogged. I am having to poke each little hole with a sharp object to break the carbon off. Might just buy a new one. Thank god i bought this bike so cheap.
#58
Use a good propane torch to burn everything out from the tube, then attack with a wire brush. Good as used in no time.
#59
I think that bike should have a AJP clutch not the magura. I have a 02 EC 200 and a 03 MC 250 and they both have AJP's on them.
02 EC 200 03 MC 250 88 VT 800 01 TXT 280 |
#60
Is it fuel / 2 stroke oil or gearbox oil ?
'00 Montesa Cota 315R '13 Husaberg TE 300 |
Help! Flywheel weight doesn't fit with 2k3 on 2003 EC250? | SideshowBob | Enduro Engine - 2 stroke | 12 | 04-28-2010 11:02 PM |
02 EC 300 wont start | GENO 300 | Enduro Engine - 2 stroke | 0 | 09-21-2009 10:02 PM |
EC200 wont start | Skele | Enduro Engine - 2 stroke | 25 | 09-06-2009 10:34 AM |
wont start | clerky clerk | Enduro Engine - 2 stroke | 8 | 11-01-2008 01:18 PM |
