Old 05-20-2015, 09:22 AM
pscook's Avatar
pscook pscook is offline
Originally Posted by Jim Cook View Post
Looking at photo #4, I see a lot of exposed shaft. How did you get the parts to compress that much? Mine seemed pretty firm when I tried to compress it to get enough clearance to get that clip off.
Thanks in advance.
Jim
The spring cup/apparatus is an (almost) interference fit. Just push harder. Then you simply twist the bendix to push everything back down.
I have replaced the GG circular spring with the Honda spring, but I haven't had the gumption to remove the hog ring from the shaft to change the gear or inner spring. I believe the inner coil spring (inside the cups) is the key to the whole operation. That lighter spring allows the gears to more easily interact, and then prevents the gears from disengaging too early.
Phil
(New bike pending...)
Old 05-20-2015, 02:56 PM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Thank you!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 11-03-2015, 11:55 AM
Scruse24 Scruse24 is offline
I just picked up a 13 300 and was wanting to stretch out the spring in the Bendix since it seems on only spin most of the time. I've taken the plastic cover off...do I need to take the metal cover off where the motor goes into as well to pull the starter out? Is there a tutorial for this? I'm a newbie to the estart stuff. Thanks for the help!
Old 11-03-2015, 12:39 PM
shang shang is offline
No. Just remove the starter from the housing. Two 8mm bolts through the plastic cover and starter into the PV cover, and the two 8mm bolts holding the starter to the stator cover. Then just pull the bendix out the top of the stator cover.
Be careful stretching the spring. I over did it and ended up buying a Honda bendix.
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 11-03-2015, 12:53 PM
Ah awesome. Thanks Shang!
Old 11-03-2015, 06:17 PM
Should I replace the grease with another kind of lubricant or leave it? Sorry for the noob questions just want to get it right the first time. Thanks!
Old 11-04-2015, 12:08 AM
I think you will want to use quite a bit of grease on the gears but I would go easy on the bendix. You want it lubricated but you don't want enough grease to interfere with its operation. It's already a little finicky. That's just my opinion anyway. That's how I did mine and it's worked flawlessly (until the other day when I punched a rock through the housing).
I think a few people on here have even sealed the drain in the cover and filled the stator housing with a few CC's of oil.
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 12-10-2015, 07:29 PM
yaphettt yaphettt is offline
Hey there I'm in need of the ring gear, where did you get yours? Been looking everywhere and I can't find one
Old 12-11-2015, 04:08 PM
CombatYoga's Avatar
CombatYoga CombatYoga is offline
Yaphettt - the ring gears are extremely hard to come by; in fact I'd venture to say there is not one in the US right now. I had Matto looking for me for one for a couple of months with no luck. A guy is parting out my model of bike on ebay and when I saw the ring gear I bought it immediately.
I think it's a combination of a commonly worn part and the troubles at the factory. Hopefully they are back in action soon and some of those hard to come by parts start flowing again.
Like Rod says, check with Matto, Halls and the other dealers that advertise on here.
Slade
'14 GG XC300R - County Cycle Woods Weapon #63
Old 12-12-2015, 07:13 PM
Combat yoga- i was able to get 1 from halls cycles thanks for the input. ordered yesterday and got it today
Anybody have an 02/03 450 FSE that actually works ? wakeymatt General Discussions & Announcements 5 08-09-2012 06:07 AM
Does anyone know how the compression release works? stay_upright Enduro Engine - 2 stroke 1 07-24-2009 10:37 AM
04 300 fork kit - Pivot Works bocoz702 Enduro Suspension 2 02-12-2007 08:24 AM
300xc what gearing works best?? Dingoe Enduro Chassis & Body 6 02-05-2007 03:47 PM
