Old 11-13-2019, 04:36 AM
Originally Posted by Gasser Nate View Post
Fair enough then, how/why did it blow up?
The piston looked like some one shot a 9mm through its top. It had just burned a hole into it...
Old 11-13-2019, 04:42 AM
Gasser Nate's Avatar
But what was the reason? Always find out the why before trying to tune a mechanical issue. Otherwise you will be chasing your tail indefinitely.
Old 11-13-2019, 07:46 AM
TGM_OFFROAD TGM_OFFROAD is offline
Melted a hole in the piston. Found the left crank seal leaking after I did the rebuild
Old 11-13-2019, 06:33 PM
Zman's Avatar
Zman Zman is offline
But does it still act/run lean like it did when it blew up?
Old 11-14-2019, 02:26 AM
No that symptom was eliminated with the replacement of the crank seals.
Old 11-14-2019, 07:24 AM
Zman's Avatar
The video you posted on TT (after doing the rebuild) going up the hill sure looked like the bike was going lean.
Old 01-13-2020, 08:44 AM
eralha eralha is offline
Hey everyone, I am trying to sort out my 18 XC 300. Long story short I had some issues with my left and right crank seals for which I ended up blowing my top end. I replaced the piston and rings, had the cylinder inspected and was told it was still in good shape. I have some running issues with it which I suspect may just be carb related, dialing in my lectron still. I can see some light through the reed pedals so I am replacing those. I have an excessive amount of carbon build up on my piston for the low hours but all other points suggest my bike is running lean. I also tested the compression but did so without the reed block in (not sure if that will lead to inaccuracy or not) and am only seeing 115psi. See video below for how the bike sounds. I have gotten some suggestions to try but looking for all the help I can get. I love the way this bike handled and the suspension is amazing after I got it valved for me. I just want the engine to run right and have the power I need
https://youtu.be/fDLVyj2sGh8
Hi i have an EC 300 2018, my bike is running like your's, i tryed cleaning up the carb e checked the reed's, with no success on solving the problem.
Did you problem got away after the crank seals replacement?
How did your problem starter? Mine started all of a sudden.
Do you have to split the cases to replace the seals?
i'm realy getting desperate with this.
Thanks mate.
2001 Gasgas EC 300 running issues. Help needed. Jdstep Enduro Intake/Carburetion - 2 stroke 6 04-10-2019 09:32 PM
300 running issues Jon250 Enduro Intake/Carburetion - 2 stroke 37 09-15-2013 05:10 PM
Ec250 running issues jimgsxr86 Enduro Engine - 2 stroke 9 05-03-2013 05:52 PM
06-300 not running davedunaway Enduro Electrical & Wiring 11 08-29-2012 09:21 AM
03 300 not running tophat General Discussions & Announcements 22 08-23-2011 03:51 AM
