Old 11-22-2019, 07:35 PM
lymebayroofing lymebayroofing is offline
Default 1998 ec250 power valve tuning
Hi was wondering if it?s possible to change the rpm at which the power valve opens if so how and would a mechanical Luddite like myself be able to do it
Old 11-22-2019, 10:33 PM
gasgasman's Avatar
It can be adjusted.
You will need to pull the right side clutch cover off.
There are some washers you can move around to adjust the preload on the power valve actuator.
Old 11-23-2019, 12:33 PM
Originally Posted by gasgasman View Post
It can be adjusted.
Ok cool I?ve been told to put a lighter spring in as well how much of an adjustment is needed to get a reasonable amount of change my power band isn?t kicking in until I?m almost ready to change gear it?s daft want it at least half way if not sooner really
Old 11-23-2019, 01:01 PM
(F5)'s Avatar
(F5) (F5) is offline
First things first. Read the jetting threads. If it is still trying to clear out too rich a mixture, that is exactly how it will feel.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 12-06-2019, 09:21 AM
on my 2006 I removed all of the pre load washers and ground the end of the springs down so there was minimal preload the shorter the spring the earlier it comes in some people have removed material from the OD of the spring and this makes the spring open quicker.
2016 RM-Z450
Old 12-30-2019, 08:25 AM
Zman's Avatar
Zman Zman is offline
Also pull the right side small PV cover off and verify the stud did not break off the PV actuator backing plate. That was a common failure for the early GG bikes.
1998 ec250 gasket kit? vaughn Enduro Engine - 2 stroke 2 11-10-2018 07:26 PM
1998 Ec250 Yokes EC250 Enduro Suspension 11 10-24-2013 07:55 PM
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
Checking for proper power valve operation 2003 EC250 SideshowBob Enduro Engine - 2 stroke 4 04-08-2010 01:00 PM
1998 Gas Gas ec250 pferreira1970 Enduro Electrical & Wiring 0 10-19-2008 11:41 AM
