Old 02-21-2018, 08:43 AM
KsGman KsGman is offline
Interesting--yes, I have it on the "rainy" setting (which is where it was set when we got it). I assumed that would be the more torque'y/lugging way to go. I will definitely switch that over and give it a comparison run.
Interesting that the needle I'm currently using doesn't seem to be as commonly used among the Gas Gas riders as it is in KTM's etc. The P.O. had the NEDW installed, so I will go back and give that a try.
Good stuff, as always!
11 Gas Gas 300 EC
17 KTM 690 E
08 KTM 300 XCW
Old 02-21-2018, 10:51 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
I moved the ignition setting switch to the handlebars, where I can flip it instantly anytime with my right thumb. (It originally came from the factory on the 2011 attached to the left bottom radiator hose.)
I think you will like the NEDW, unless it is too "flat" for you. It is a good working jet needle for our carbs, with a very smooth transition into midrange. I have not yet ridden my 2011 as a 300, yet, so I can't give you personal feedback on the jet needle I prefer with it as a 300. I do know that the AS2 PWK that came on my 2011 definitely requires leaner jetting than the older AS1 carb that came on the earlier model GasGas bikes, on which I did such extensive testing.
My favorite PWK AS1 jetting sucked when I tried to use it on the 2011 250 with the AirStriker2.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Carb jetting 200 EC maclab56 Enduro Intake/Carburetion - 2 stroke 10 05-10-2016 05:40 AM
No rear brakes - troubleshooting tips CombatYoga Enduro Chassis & Body 1 06-11-2015 09:58 AM
98 ec250 carb and jetting OKFiremanMark Enduro Intake/Carburetion - 2 stroke 5 07-22-2013 04:00 PM
2013 EC 250 carb/jetting Earwinder Enduro Intake/Carburetion - 2 stroke 4 05-20-2013 04:35 AM
Jetting: 2011 250 (38mm carb ASII) Jakobi Enduro Intake/Carburetion - 2 stroke 53 07-23-2012 06:31 PM
