Old 01-02-2014, 04:55 AM
andy176 andy176 is offline
Default 2002 ec300 stuck in 6th?
A fella I ride with was out the other day and his 300 is now stuck in 6th gear I wasn't out with them and havnt seen the bike so I don't know if the shift lever is moving free or if it's stuck solid but he's lookin a hand work at it. Would any of you have had this problem or know wat could b the cause thanks.
Old 01-02-2014, 05:29 AM
bowhunter007's Avatar
bowhunter007 bowhunter007 is offline
Do you if it wouldn't downshift from a lower gear, and he shifted it up to 6th, then it wouldn't return. Open the clutch side & check the actuator and spring...otherwise, bent shift shaft? I just resolved a similar issue. It was a 10 sec repair, with a 90 min disassembly & reassembly.
All healed up, and ready to burn some fat.
Old 01-05-2014, 11:57 AM
v-tec v-tec is offline
My mates 2011 300 did this and the weld on the selector shaft had sheared right off
V-tec
problem 2002 ec300 wont rev out? andy176 Enduro Engine - 2 stroke 17 10-07-2013 07:54 PM
ec300/2002 ghostypoodle Enduro Engine - 2 stroke 4 06-25-2012 12:18 PM
