Old 04-29-2012, 07:43 PM
Gasaholic Gasaholic is offline
Default 2011 EC300 Clutch drag
Just went on first trail ride on newly purchased 2011 300. The clutch seems to be losing it's hydraulic pressure. If I stop and hold the clutch in while in gear the clutch will start to drag and bike will creep and if brake is applied will stall motor. If I leave out the clutch and move forward but then pull clutch in again it's fine unless I sit and hold it again then it will go through the same problem . Anyone have this symptom or know what I can try to correct this. It's very hard to ride gnarly single track when the clutch has no release point and drags to the point of no clutch response when trying to slip. If I stop and kill motor and find nuetral and work lever a few times it will work as it should until I have to hold it in or try to slip it. Does it just need bled? When we got back to truck we pulled the maser cylinder cover and the mineral oil looked dark or off color, has anyone found contaminated fluid ?? Love the bike just can't live with the clutch working this way. Any Ideas or suggestions???
Old 04-29-2012, 08:29 PM
Mazikeen Mazikeen is offline
It is not right, My mineral oil is clear. I was sitting here trying to think of how you could isolate the master and slave cylinder to determine which is your leakdown point and it occured to me you may have an issue with the slave cylinder as that is the only place it could pick up a contaminate? I've not taken mine off yet, so not sure what the true potential is, but I suspect that is your leak. There must be some form of seal between the slave and the gearbox. Regardless, if it is contaminated you will need to have both the master and slave replaced as the oil will cause long term issues with the seals.
As I understand reading these forums, gasgas is quite responsive to initial build quality, so I would make a quick call before delving in real deep to prevent warranty conflicts.
Old 04-29-2012, 08:30 PM
gasmonkey's Avatar
gasmonkey gasmonkey is offline
Bronze Level Site Supporter
Sounds like the master cyl is leaking back into it's resivior when under pressure.
Get the dealer to swap it out with another new one.
If there's no warranty fit a new seal and piston kit bc25922219.
Old 04-29-2012, 09:09 PM
Default 2011 Clutch
Thanks for the quick response, I will investigate both sugesstions and let you know how I made out. Thanks
Old 04-30-2012, 09:07 PM
Default Clutch
Bled the bad oil out and it seems to be working for now. time will tell
Old 04-30-2012, 10:49 PM
I'm pretty sure there were a bad batch on some of the late model 2010 or early 2011's that were known to exhibit this behaviour. A search should turn up some info. I think maybe GGEvo had it happen on his..
Old 09-30-2012, 06:48 PM
Larsa's Avatar
Larsa Larsa is offline
Default Same problem
I have the same problem on my late 2010 EC300. I think I need to order BC25922219
Cur GasGas GP 300-18, Prev GasGas EC 300 Racing-13, GasGas EC 300-10, GasGas EC 300-07 GasGas EC 300-05, GasGas EC 250-02,Suzuki RM250-98,Suzuki RM250-88, Honda CR250-86, Yamaha YZ400-79, Beta CR125-81, SWM 50-77, Italjet 50-76 www.dufvenberg.com
/Larsa
Old 10-03-2012, 07:43 PM
Larsa's Avatar
Default Varning do not order BC25922219 wrong part nr
Part number BC25922219 is for the supermotard clutch cylder repear not for the EC or MC model.
The correct part number for EC or MC is BT27722208
/Larsa
Yes my Clutch does drag. (F5) Enduro Engine - 2 stroke 42 04-09-2019 12:11 AM
Clutch drag.... BluegassXCR Enduro Engine - 2 stroke 3 07-04-2011 03:27 PM
Does your clutch drag? stay_upright Enduro Engine - 2 stroke 11 06-05-2008 03:14 AM
Clutch Drag? Gas Huffer Enduro Engine - 2 stroke 5 12-11-2007 05:02 AM
05' EC300 Clutch Drag gasIdaho Enduro Engine - 2 stroke 18 09-09-2006 02:53 PM
