Old 04-09-2019, 05:34 PM
dANbOT's Avatar
dANbOT dANbOT is offline
Default Ignition map switch wiring
Im pretty sure I know the answer, but...
On my 2014 xc300re, does anyone know if the map switch is in reduced power mode with the circuit closed?
I just replaced my harness and installed a generic switch and want to label it correctly. It's just an on/off switch.
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 04-10-2019, 02:57 AM
Anders Anders is offline
I can check it at my own 15 model, but I cannot do it until tomorrow evening my time. I plan to spend some time in the whokshop then.
On the old bikes (as my 06 model), closing the switch gives you the "sun" setting.
Old 04-11-2019, 06:24 AM
dANbOT's Avatar
I appreciate you looking, I'd test my original switch bit I threw it out before I realized I needed the info
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 04-11-2019, 12:19 PM
My switch is similar to my older one; Closed switch = Sun mode.
Open switch = Rain mode.
My ignition module may differ from yours, as I have a 2015 kick start EC200. But I would be surprised if the switches are different
Old 04-11-2019, 02:15 PM
dANbOT's Avatar
thank you very much, I agree there is most likely no difference.
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 04-11-2019, 02:23 PM
dANbOT's Avatar
All set!
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
WTB ignition switch nmrider "Wanted to Buy" & "Want To Trade" 1 02-09-2015 10:09 PM
'06 ignition mapping switch brider Enduro Electrical & Wiring 4 09-17-2013 06:53 AM
Ignition curve switch wiring - Dual Mapping smallpuffydog Enduro Electrical & Wiring 5 09-08-2011 02:04 PM
dual ignition switch ktmguy23 Enduro Electrical & Wiring 1 09-11-2007 05:21 PM
