Wheel bearing replacement
I have just replaced all my wheel bearings and seals. Approx. 4000km. 2 of them needed replacement due to water ingress, the others felt OK but I replaced them anyway. I used SFK bearings and seals sourced at trade prices direct from SFK New Zealand head office. This worked out to be about twice the price of the "All Balls" kits which I could have bought on line. I hope it was worth the extra dollars. I must admit I was a bit suprised. The 2 front bearings were $NZ 35 each due to being "narrow", according to SKF.
As for the infamous spacer between the 2 sprocket side bearings.... I found mine to have the same dimension step on both sides, so it could fit either way. It is simply a 2mm spacer that keeps the 2 dissimilar sized inner races apart i.e squeezed together when the axle is tightened. Wear is evident on both sides of this spacer - seems like a bit of poor engineering design, and then to make the thing out of aluminium? ?
Barry 07 EC250 |
Iv done 100 hours and just replaced both my wheel bearings. I used the all balls kits, but pulled the seal back and filled with more grease.
As for the spacer, I found that mine was definately directional, should be slightly concave. I think the spacer is there to distribute the force of tightening the swingarm bolt away from the centre of the bearing the axle runs in. The spacer runs in the outer bearing, gets loaded up from the axle and the spacer is pushed onto the outside on the second bearing. If it wasnt there, then tightening the axle would crush the bearings. The front wheel bearing kit is the same as the kit for an LT50 |
This means there is a shear type force on the 2mm aluminium spacer washer, because of the 2 different inner race diameters, and that's why it was concave. Mine wasn't but there was some wear marks on each side wear the inner races were. It's hard to put in words but I know what I mean! The underlying principle is : the inner races of all the bearings must be squeezed tightly together by the axle. The outer races "float" in the hub
Barry 07 EC250 |
Front wheel bearing life | roostafish | Enduro Chassis & Body | 11 | 12-27-2010 11:55 AM |
Front Wheel Bearing Removal | coolum74 | General Discussions & Announcements | 13 | 02-24-2009 03:29 PM |
05 250 front wheel bearing seal #??? | Bandit9 | Enduro Chassis & Body | 3 | 10-29-2007 06:49 PM |
Rear wheel bearing ? | ktmguy23 | Enduro Chassis & Body | 1 | 03-22-2007 06:45 AM |
Steering Head Bearing Replacement... | tprnottp | Enduro Suspension | 7 | 10-30-2006 08:45 PM |
