Old 04-13-2020, 07:02 PM
adriangtzxr's Avatar
adriangtzxr adriangtzxr is offline
Default Shiver 45mm Compression clicker leak
My compression clicker is leaking like a sieve. I am assuming that it is a bad internal o-ring and maybe some dirt.
I have the lower compression (nut) unit out but that is as far as I can go. Replacing the larger external o-ring while I'm at it. I can not figure out how to disassemble the unit to extract the screw. No snap rings that I can see? I have attached a few photos. Any tips are appreciated!
-Adrian
Note: The bike is a 2009 GG six days (allegedly) Forks didn't have markings so making the assumption it is a shiver 45mm due to diameter and physical appearance. The Marzocchi shiver manual was no help.
Old 04-13-2020, 07:15 PM
frankinberg's Avatar
Looks like A zoke bottom valve
Old 04-13-2020, 11:39 PM
Issue solved, it was swedge from factory. Took the soft metal down until it was flushed and popped off the washer. This allowed for the screw to back out.
Marzochhi Shiver 45 , Compression clickers at top or bottom? HerminatorZA Enduro Suspension 2 08-03-2015 10:31 PM
Compression clicker not clicking, 45mm Shiver hillbilly Enduro Suspension 3 05-11-2015 04:15 PM
marzocchi 45mm shiver johall865 Enduro Suspension 0 12-28-2014 06:55 PM
2014 Reiger Shock Compression Clicker?? EC_CC_Rider_300 Enduro Suspension 2 06-18-2014 07:12 AM
wtb marzocchi shiver 45mm mbogage Parts 1 01-12-2014 09:21 PM
