Old 01-10-2017, 09:10 AM
tafy83 tafy83 is offline
Default Installing a LED work light for a headlight
Hi All,
I'm toying with the idea of swapping my standard headlight to an LED work light the bike is a non elec start 2013 300 ec factory. I understand that I would need to change to output from AC to DC but I'm hopeless with electrics.
http://www.ebay.co.uk/itm/2X-27W-LED...QAAOSwa~BYOfR2
Any advice or guidance would be appreciated.
Thanks
Ian
Old 01-10-2017, 12:05 PM
adriano.ro adriano.ro is offline
I just made that move! The result is awesome! I just wire up ,no oder modifications.
Do you see some similar on Facebook.......?
Old 01-10-2017, 01:11 PM
Neil E. Neil E. is offline
The light in your link does not specify DC voltage. It is possible that it may function on AC. LED emitters can work on AC, they just aren't as efficient. In most cases a DC specification means there is some circuitry in the light that must be powered using DC current.
There are some lights that do list AC voltage since they have internal rectifying circuitry that will convert the AC voltage to an internal DC voltage.
Try the light and see what happens. In the worst case you will need to add a voltage rectifier. This could be a small fullwave rectifier directly in series with your light.
Old 01-10-2017, 02:50 PM
john r b's Avatar
john r b john r b is offline
I have been running a unit from OPT-7 FLUX BEAM it's plug and play seems well built.
www.OPT-7.com
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 01-10-2017, 03:16 PM
Default ..
Winner thanks Neil, will take your advice and fit a rectifier.
Thanks Again Buddy
Old 01-10-2017, 03:34 PM
VilluEST VilluEST is offline
If your bike already has lights, I'm pretty sure you have DC system on it, even without estart, especially on 2013. All 2014 have DC and they didn't change electrics. It was the older bikes that had AC only.
Old 04-25-2020, 09:50 AM
Joehunt's Avatar
Joehunt Joehunt is offline
Sweet
I?ve been wanting to add a fan and led head light to my 14 ec300r for a while. Now I know I have dc power. Was a little unsure.
Joe
2014 ec300r
Installing S3 FWW on ec300 race Terrence R Enduro Engine - 2 stroke 11 06-16-2015 08:30 PM
Need a headlight that will work on a 99 EC200 flatout111 "Wanted to Buy" & "Want To Trade" 5 07-10-2013 08:14 PM
gg rear brake light/enduro computer/headlight jt633 Parts 3 03-10-2013 10:27 AM
2001 EC300 Headlight won't work bexi Enduro Electrical & Wiring 9 03-13-2010 11:12 PM
Installing new Air Filters warnzie Enduro Intake/Carburetion - 2 stroke 7 11-27-2007 07:10 AM
