Old 01-22-2019, 12:10 AM
Tafka Tafka is offline
I got the issue fixed by myself, i sold the bike after i fixed the problem!
Problem fr me was worn out TPS and little bit helped if i changed the injector also.
Old 01-23-2019, 06:09 AM
expirmininkas expirmininkas is offline
Thank you very much for sharing. So basically you have hanged a worn out Throttle position sensor?
P.S. information to all other riders of GG that I've learned from local dealer - main ECU is the same as Sherco using. So, information, relevant to Sherco, may be relevant to GG (mutatis mutandis in legalize so to say)
Old 01-24-2019, 12:49 AM
I actually cleaned the old TPS....it's not meant to be opened but carefully opening it and the glue back.....
Many bikes use that ECU.....Sherco (up to 2013, from 2014 Sherco uses much better Synerject), Ducati,Piaggio uses the same....but there might be trouble to upload GG MAP to other ECU. Somewhere in this forum there was one user who had trouble uploading GG map to Piaggio ECU....but there was somekind of fix.
Old 05-30-2020, 04:04 PM
Luurij Luurij is offline
VAG coil did not work! At least one that i tried....but theres many many versions of VAG coils.
Connector may be the same but that doesn't mean it works.
But if you say your coil has VW/Audi logos then share a picture or part number for others
I know this is an ancient thread, but I bought an 2007 450 fse last week that has a VAG coil on it and works just fine. I can make a photo of the part numbers on it, if anyone is interested.
Ps! Tere Tafka!
Old 06-01-2020, 12:32 AM
Ps! Tere Tafka!
Tere tere
Yeah, put a picture here! But isn't 2007 already with 3-pin coil?
There were so many versions of the VAG coil and one that i tried didn't work.
Didn't want to spend money, trying them all :P
Old 08-23-2021, 01:09 AM
Greedy Guido Greedy Guido is offline
Default MFS400380006 wire for MFS450780006
Have a 2007 GasGas 450 FSR that has always been a bit hard to start but now it won't start at all.
I have access to a 4 pin MFS400380006 coil, can this be wired from a MFS450780006 3 wire connection (Thinking plug has two commons.) to allow testing.
testing lighting coil bonkeye Enduro Electrical & Wiring 7 05-09-2012 07:51 PM
FSE Coil-on-plug ohm readouts? bergerhag Enduro Engine 4 stroke (including EFI & Exhaust) 1 10-20-2008 03:05 AM
Coil? bronco-hunter Enduro Electrical & Wiring 0 07-28-2008 06:48 PM
