Old 11-17-2008, 10:56 AM
cal_tony cal_tony is offline
Default Will anything other than a GG rear wheel fit on a GG?
Since I have had very limited answers to my previous questions re. my new GG, I thought not only would I ask a new question, but I would go so far as to provide the answer as well.
Not sure what else will fit my 450 FSE, but for sure, with out anything other than a little grinding on the DRZ spacers and the GG brake bracket, my DRZ 400 SM wheel will fit just fine with a 150-60-17 tire. The only insurmountable problem seems to be that the DRZ SM is fitted with a 240 mm rotor. I am going to order a DRZ S model rotor (220 mm) same size as the GG and that should fix that problem. Once I get it working properly, I will buy a new DRZ 17"wheel set up.
I'm still working on what to fit on the front. So far, the only candidate is a late model Husky wheel.
Tony
Old 11-17-2008, 11:27 AM
Rick's Avatar
Rick Rick is offline
Check your pm box!
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 11-17-2008, 09:27 PM
HydroDog's Avatar
HydroDog HydroDog is offline
Well I'm not sure if the 2 stroke wheels are the same as the 4 stroke but I have put a 1989 Honda CR250 rear on my 07 EC 300.
Direct swap, didn't have to change the spacers or rotor.
07 GG EC 300
05 KTM 250 exc
99 KTM 640 enduro
Old 03-03-2013, 10:50 AM
nokturnal nokturnal is offline
So an 89-97 CR250 rear wheel will work on a 04+ gasgas?
06 EC300
Old 03-03-2013, 12:22 PM
nick H's Avatar
nick H nick H is offline
I would like to learn more on the honda wheel fitting did you use a 19 or 18 in rim? does it matter size of rim? and you used the honda spacers. wondering if I could get a new wheel from say warp 9 if it would work? they stopped making gg wheels thanks for the info
2013 xc 300
Old 03-03-2013, 03:03 PM
bowhunter007's Avatar
bowhunter007 bowhunter007 is offline
My 2001 XC 250 has a 19" 1995 KX 250 wheel, including rotor & spacers. I installed a 54T sprocket to accomidate the extra diameter(13/54, 19" wheel...works great in the mountains).
All healed up, and ready to burn some fat.
Old 03-03-2013, 05:26 PM
He used the complete wheel and spacers from an 89. 18". looks like wapr9 makes them, listed as 89-97, so I assume they are the same through those years. Spacers may not be the same as the gasser though...
06 EC300
Old 10-02-2013, 11:20 PM
s1n15ter1 s1n15ter1 is offline
I have a line on a 90's cr250. Any word on if the front wheel will swap over? please advise.
