250 to 300 cylinder swap (search for torque)
Has anyway swapped their 250 to a 300 with the cylinder head kit?
This is my first 250 2-stroke Iv always been a 4 stroke or 300xc KTM guy.. I really like my 2019 GG 250xc but it is in my opinion a zingy 250, like a yz 125.. (ok maybe not that zingy 😆 but you get the idea. I like bottom end torque, I ride down low in the meat. Iv looked at the 300cc cylinder head swaps on eBay.. just wonder if it will be worth the money? technically speaking it should be really? but I also have never rode a GG300 so are they tractor pull, grunt workers like the KTM 3honey? Also, would swapping out the FMF fatty for a Gnarly make much of a difference? (Pre-cylinder swap that is) it would be nice to just swap out pipes in order to gain what I want but I just can see it making ?that big? of a difference alone. And yes, most people will suggest ?do the gnarly pipe first and if it?s not enough so the cylinder swap??. Yes, thank you.. that?s great advice. I?m wonder more if anyone has already experimented and could share their thoughts on rather the expensive cylinder swap is money well spent or is the slightly cheaper (not by much these days) gnarly pipe a good change to gain low end?
2019 GasGas XC250 |
You can adjust the power valve for more low end power.
I have tried these pipes on my '18 250. The Gnarly will give you more low to mid power. The Fatty; more mid to top end power. Pro Circuit. more mid to top end power and increased over rev. Can't recommend the Pro Circuit. as the silencer inlet has to be expanded to slide onto the PC pipe. |
Easy peezy
Turned 2 250s into 300s. If you like 300s the gasser will make you smile. If you like your bike to sing 250 if you want grunt 300. Gnarly pipe more torque and beefier build quality.
Good luck |
Trying a decent needle first will change the power delivery
One more option is to convert your 250 into a 265 with a Big Bore kit. I built a 265 last summer and while it does not have the bottom end of a 300, it does make a nice increase over a 250 with better low end and mid-range power combined with the ability to scream up top.
2019 300/250 cylinder swap | IdahoUSA207 | Enduro Engine - 2 stroke | 1 | 12-23-2021 11:48 AM |
Trick to torque recessed cylinder nuts | d2w | Enduro Engine - 2 stroke | 9 | 02-13-2014 10:13 AM |
Setting new cylinder studs - torque | motogroove | Enduro Engine - 2 stroke | 3 | 07-20-2011 02:04 AM |
Torque cylinder head EC 300 2009 | Klausen | Enduro Engine - 2 stroke | 9 | 10-03-2010 10:49 AM |
Cylinder Bolt Torque? | eff | Enduro Engine - 2 stroke | 12 | 03-30-2008 08:44 AM |
