question about xtreme and power new cylinder heads
hello!i have a 2009 ec300.if anyone knows please answer me if the new type cylinder heads from s3 have different squish.new i mean that before was one head with 3 or 4 different inserts but now i see only 2 heads extreme and power.do they have different squish between them or the squish is the same but changes only the shape of the dome?
my bdc is flush with the cylinder port so i cannot change the gaskets and i have 2.2mm squish with stock head and i was wondering if i can lower it with a ready cylinder head and not playing with the stock head!thank you in advance!also i would like to ask if i will see any difference with the gpr expansion chamber cap for the side of the power valve.has anyone try it? |
Tags |
ec 300, extreme, gpr, power, xtreme |
power valve 2006 on 2013 cylinder | Siggewiksson | Enduro Engine - 2 stroke | 2 | 02-06-2020 06:56 AM |
power valve question | Getoviq95 | Enduro Engine - 2 stroke | 2 | 07-11-2016 02:40 PM |
S3 cylinder/power valve help? | '11EC300 | Enduro Engine - 2 stroke | 7 | 06-02-2014 08:18 PM |
Need power? had to raise cylinder .095"(2mm+) | socalscott | Enduro Engine - 2 stroke | 13 | 01-08-2009 09:19 PM |
Video: Hancock, NY 2007 Xtreme test | Berkyboy | General Discussions & Announcements | 3 | 07-23-2007 11:45 AM |
