Old 05-08-2014, 02:10 PM
StuJohnson's Avatar
StuJohnson StuJohnson is offline
Default 2012 -- Bent Kickstand Bolt AGAIN
Seriously.... Am I the only one who hates the kickstand design on my bike???
I so want to take a torch and just cut and rip the SON OF A B$%^ off
Sure a lot of you say just get rid of it. Maybe I will. It really does not work for me. But there are so many times it comes in handy too.
I keep looking at all the other bikes kickstand designs. Like the promoto one for KX450 that is integrated into the foot peg mounts (thanks Desertgasser for that one). And the KTM ones are nice too.
I know this had been discussed a lot on here. But any others have good ways to keep the damn Grade 8 bolt from bending?
I am so tempted to modify my foot pegs mounts like the KX450. But that require quite a bit of work to the frame and if not done properly then would be a huge mistake....
2012 - XC 300 Racing
Seattle, WA
Old 05-08-2014, 02:17 PM
StuJohnson's Avatar
The black bolt is a grade 10 bolt. Lasted 2 rides.
The silver one is a grade 8 bolt. Lasted 2 times in garage... Obviously I used the wrong bolt.
What length is in your bike for this bolt ?
Seattle, WA
Old 05-08-2014, 02:26 PM
phoenix's Avatar
phoenix phoenix is offline
I went through four bolts before finally just ditched the kickstand. And I HATE not having a kickstand - sometimes a tree or fence post isn't around. And I get tired of the question...hey did your kickstand fall off?
I tried keeping it lubricated, I tried various different bolts, and I tried putting nylon shims in and it still gummed up and bent. I have never had this much trouble with a kickstand ever. I'm not sure if the bolt, itself, is the problem or just the design...crap just seems to get into the bolt hole and seize the thing up.
I wish the frame covered both sides of the top of the kickstand so that the bolt just making contact with the frame and not with the kickstand directly.
2009 Husqvarna TXC 450
2013 Husaberg TE 300
2014 Gas Gas XC 200
Old 05-08-2014, 02:45 PM
Buysomerice's Avatar
Buysomerice Buysomerice is offline
My 12' is exactly the same. Tried long, short, and all the way to grade 10... It always bends. Next step is dremeling a void in the stand so the head of the bolt doesnt contact the stand at all. Insted it will bottom against the spacer/bushing thing that runs thru the stand. I dont take credit on that idea, I've read it on this forum somewhere. I can't say goodbye to mine either so its just bolted down tight till I get some time to try that.
Old 05-08-2014, 03:30 PM
Do you blokes let it auto retract?
Old 05-08-2014, 03:40 PM
nknudsen's Avatar
nknudsen nknudsen is offline
Mine isn't a 2012 but I never let it slam up by it's self. I always hold my foot on it when it goes up. It retracts so hard I figure it might break something not letting it up easy over time.
Noah
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
15' TW200
Old 05-08-2014, 03:53 PM
StuJohnson's Avatar
I hate that part too. I seriously have a permanent dent in my shin from that...
Lighting up the blow torch now... ;-)
Seattle, WA
Old 05-08-2014, 04:36 PM
VxZeroKnots's Avatar
VxZeroKnots VxZeroKnots is offline
I shimmed with a different spacer so the bolt head doesn't contact the stand and that has seemed to work the best out of anything I've tried.
Old 05-08-2014, 04:46 PM
phoenix's Avatar
I'm going to try the dremel trick tonight. I really miss my kickstand.
I honestly can't remember if I let it auto retract or not, it has been so long, but I'll assume I did if that seems to be a big source of the problem.
2014 Gas Gas XC 200
Old 05-11-2014, 07:05 AM
hamilton's Avatar
hamilton hamilton is offline
The spacer must be wider then the kickstand to maintain bolt torque. When new I removed a small amount of material from frame side of kickstand at spacer area. No problems for over a year. But don't let the stand sink in the mud and fall over you will snap the bolt. The EE stand foot helps with that.
15 GASGAS EC 250
19 Sherco SE 125R
Is my pipe bent eviljim Enduro Engine - 2 stroke 6 06-10-2013 02:22 AM
2012 bolt on bits. nato General Discussions & Announcements 9 08-11-2012 02:37 AM
Bent foot peg pins tnttimber Enduro Chassis & Body 3 11-03-2011 08:57 AM
Radiator Bent Niloz Enduro Chassis & Body 1 11-10-2008 01:18 PM
bent pipe. rupecopp Enduro Engine - 2 stroke 2 10-11-2008 11:14 PM
