Old 09-23-2012, 09:17 PM
BryanMcc BryanMcc is offline
Default 2010 ec250 jetting
hi guys, working on my little brothers jetting.... stock in bike was a 180 main, N1EF needle in top clip pos and 40 pilot. Bike had a ton and i mean ton of spooge, sort of hard cold starting and a slight bog on the main. I changed the main to a 178, ran fine at 5k feet 50 degrees still had a slight bog at 7to 8000 feet, so ill probably leave that. I also tried theJD blue needle in clip pos 3. Bike ran very nice midrange, with little spooge. Much better than stock. also tried the other needle that came with bike CHN in middle clip pos. Bike was very lean so i went back to the JD needle. Can anyone give me a needle rec?? He doesnt want to spring for a JD kit, so i think we will try yamaha or suzuki needles since we can get them for 10 dollars each. one with a similar size as JD blue would be awesome since he liked how that needle ran. Thanks!
Old 09-23-2012, 10:35 PM
WTEC's Avatar
WTEC WTEC is offline
In my 2010 I run 168 main, 35 pilot, and the "W" diameter YZ250 needle in the center clip (can't think of the whole number right now) at similar elevations. Check which carb you have as well, mine has the 38mm with a #7 slide. Don't worry about the spooge, mine still spooges with this jetting running Amsoil Dominator at 50:1. With the stock jetting I had unburnt fuel running out the power valve drain, it was WAY too rich.
Wes.
13 EC200 Race
10 EC250 Six Days (SOLD)
07 EC250 (for sale)
85 RZ500
75 XL250
71 CB100
08 DRZ70 (son's)
Old 09-24-2012, 12:55 AM
gasmonkey's Avatar
gasmonkey gasmonkey is offline
Bronze Level Site Supporter
suzi needles/nedw=jd blue;nedj=jd red<>.Jake can you confirm?
Old 09-24-2012, 02:13 AM
i know the JD tapers will be slightly different but if the dimensions worked out to be close with those needles that would be sweet, Jake what needle did you settle on in yours again?
Old 09-24-2012, 06:00 AM
Negative. The JD blue is closer to an F diameter needle. The Red is close to a H/W. The JD Red#3 is very similar to N3EH#3.
If its the older PWK AS1 (deep bowl and screw on cap) it will prefer the richer diameters by nature. Most find a G works well. Maybe try an N3EG.
In mine with an AS2 I run 40 N3CW#3 178. N3CW is a half clip leaner than the stock N3EW Yamaha YZ needle for 2007+
Jetting 2010 xc200 blanc Enduro Intake/Carburetion - 2 stroke 21 07-02-2011 02:11 PM
2010 EC300 Jetting mrfallover Enduro Engine - 2 stroke 1 12-10-2010 03:20 AM
2010 250 EC Jetting. enduro1 Enduro Intake/Carburetion - 2 stroke 13 08-19-2010 05:56 PM
2010 EC250 Jetting WTEC Enduro Intake/Carburetion - 2 stroke 1 03-26-2010 09:41 AM
jetting for new 300 racing 2010 fabulous furry Enduro Intake/Carburetion - 2 stroke 9 08-11-2009 09:28 AM
