Old 12-30-2008, 12:29 AM
brains's Avatar
brains brains is offline
Default 99 - 02 KX plastics on GG 05
I saw a post from 06 saying that they look like they may work.
Has anyone tried it out?
Old 01-02-2009, 07:17 AM
mxdj2003 mxdj2003 is offline
they wont work with the stock subframe, but the 99-02 kx subframe will fit with very little modifications, all you have to do is heat and bend the top tubes on the subframe down about a 1/2 inch, the airbox lines up but the flange is way bigger then the GG and is a loose fit on the carb
Old 01-02-2009, 12:46 PM
brains's Avatar
Thanks, I am thinking about only using the rear fender of the KX? as I want it in black.
Old 01-02-2009, 07:03 PM
rpduc rpduc is offline
Yup, I have white UFO front and rear fenders for a KX on my '05 MC 250.
I don't remember for sure, but I'm guessing I went with the '94 - 98 KX rear per this chart
http://www.gasgasrider.org/html/parts_crossover.html
I didn't have to "modify" the subframe in any way. I may have trimmed a bit of plastic, but I don't remember it being much of an ordeal.
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
'06 Duc S2r 1000 R.I.P
May be so... May be not so...
My Website
Old 01-03-2009, 09:30 AM
JEEPUSAURUS JEEPUSAURUS is offline
'94-'98 kx rear fender is a bolt on
99 EC 300
Old 01-03-2009, 03:18 PM
reeve reeve is offline
where do you mount the cdi on the kx fender? as on my 06 ec200 it is mounted on the back of the fender and i believe the 05 and 06 share the same rear fender
Old 01-03-2009, 03:23 PM
I think "some" '05s did not have the cdi back there. My '05 MC has it mounted above the airbox like earlier models so no issue.
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
My Website
Old 01-03-2009, 04:19 PM
Not really sure on the '06 model, but on '02 and '03s that i have worked on they are on top of the airbox in front of the filter, and on my '98 it is mounted on the back of the airbox in front of the rear fender, and the airbox covers the rear fender on all three, so the fender shouldn't have any thing to do with mounting the cdi, but like i said i have not seen an '06 so look and see, but i believe the airboxes are the same from '02 to '06.
99 EC 300
Old to new plastics fastfilli Enduro Chassis & Body 2 01-24-2010 09:04 AM
gas gas plastics randy General Discussions & Announcements 2 11-07-2009 02:41 PM
gas gas plastics johns2394 Enduro Chassis & Body 1 12-09-2008 06:44 AM
kx plastics reeve Enduro Chassis & Body 14 09-24-2008 07:53 AM
Where to get plastics 98 EC - UK jazzy Enduro Chassis & Body 0 09-24-2008 04:43 AM
