Old 12-19-2012, 08:15 PM
gas-gas 52 gas-gas 52 is offline
Default 2012 ec300 running bad 1/4 to 1/2 throttle
Need some help on which way to go on jetting. I have a 2012 ec 300. It has a bog from 1/4 to 1/2 throttle. Elevation here is 800 to 2500 ft. Above sea level. Installed a J D jet kit, 180 main 40 pilot blue needle n the 3 clip, air screw 2 turns out. Still has a little bog in it but better than stock. Would like any help that anyone could give me. I also have a 2011 300 that I put the same kit in and ran perfect . Thanks
Old 12-19-2012, 08:31 PM
gasgasman's Avatar
Try a new spark plug.
Fought this on my 2011 when it was new.
Old 12-19-2012, 09:10 PM
Will try that. Thanks
Old 12-20-2012, 11:26 AM
GMP's Avatar
GMP GMP is online now
That needle and main run perfect in my 250s, surprised they are not rich in the 300. Slides the same? Try swapping carbs. From my experience when you start to get off the map with jetting in an attempt to cure a problem, something else is wrong.
Old 12-20-2012, 02:21 PM
Yep! Confirm both carbs are the same too. Swapping is a good way of isolating it and removing variables. Different model carbs have very different jetting requirements. If the 2012 has the AS2 38mm then I am not surprised that the jetting is off.
Old 12-20-2012, 09:55 PM
Thanks, that's a very good ideal.....will try it and get back to you
Old 12-20-2012, 10:48 PM
Might as well pull the reed block and check the petals while you're in there too. Its only a few extra bolts. If its low hours its unlikely they'll be damaged however I know of a couple bikes that managed to chip the lower rhs ones where they contact the cases.
Long throttle cable for raised bars on 2012 wence Enduro Chassis & Body 14 02-07-2017 12:04 AM
2012 EC250 or EC300 Black01 General Discussions & Announcements 34 08-08-2012 05:40 PM
Throttle sticking on EC300 2007 Malcolm Enduro Engine - 2 stroke 11 07-19-2011 03:14 AM
My 06 EC300 not running properly! ju571n Enduro Intake/Carburetion - 2 stroke 21 07-26-2009 06:57 AM
