Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 08-28-2018, 02:53 PM
Moto7man Moto7man is online now
Default Reassembly Begins!
The powdercoated parts just arrived last night. So, assembly will begin this week.
Here is the frame.
Rear brake lever.
Cylinder and head.
Head again.
Rear brake drum and backing plate.
Wheels and engine cases.
Triples and rear suspension components.
Radiator guards.
―Comedian Lewis Black
-Unknown Sardaukar
Old 08-28-2018, 03:03 PM
Front hub and backing plate.
Foot pegs, stock and upgraded.
Swingarm
Another shot of the brake pedal with the folding tip.
Silencer soon to be modified into a spark arrestor.
Triples again with rear brake arm and rad guards.
Cylinder head with water pump and outlet.
-Unknown Sardaukar
Old 08-28-2018, 08:03 PM
(F5)'s Avatar
(F5) (F5) is offline
Looking forward to seeing the result.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 08-28-2018, 09:21 PM
I am looking forward to that too.
-Unknown Sardaukar
Old 09-08-2018, 12:36 PM
Default More Progress
Almost done with the seat. I have two bolts to install under the seat, then I can stretch the cover tight and it will be ready.
CDI and Coil mounted up.Just waiting for a oem protector and mount for the CDI.
New steering head bearings installed with the triples. Bottom bearing is a tapered bearing and top bearing is a older design roller bearing, but the top bearing mounted up tight with low drag and smooth action. There is a kit to covert the top bearing to a tapered bearing but it requires machining the stem slightly. The oem design seems very strong so I decided to go with it. I know this bearing is used on several other suzuki models. The design is a little strange and the inside machining inside the top of the steering head looks two races but they are not removable races just machined surfaces into which the new races(roller ball or tapered) are inserted.
I think the frame turned out nice. Here are some shots of the frame.
-Unknown Sardaukar
Old 09-08-2018, 12:49 PM
Tank mounted, just waiting on some bolts.
-Unknown Sardaukar
Old 09-08-2018, 12:58 PM
Default Triples
The top triples have rubber mounts. I ordered some Protaper replacement rubber bar mounts that should be here tomorrow.
-Unknown Sardaukar
Old 09-08-2018, 06:01 PM
She's coming up a treat mate! Love following threads like this.
Old 09-08-2018, 11:54 PM
Thanks! After I get this one done, I think I am going to do what you did and buy a new gasser in the spring.
-Unknown Sardaukar
Old 09-20-2018, 02:19 PM
Default New Pro Taper Rubber Mounts
I decided to go to the bigger bars on the RM. I was able to find ProTaper Mounts with Pro Taper Replacement Cone Kit.
Pro Taper Bar Pad
Everything bolted right up and I torqued the bolts to 27 foot pounds per the protaper instructions. The suzuki manual has a spread of torque values that are acceptable to adjust the feel of the rubber cones. I will post an update later.
Bottom
Partially bolted up with new throttle, clutch and front brake cables.
-Unknown Sardaukar
94 CR 250 Ground Up Restoration IMS Wide Ratio Transmission Issue Moto7man All Other Bikes... 146 01-28-2018 05:57 PM
1994 CR 250 Restoration featured on Dirt Bike Magazine Webpage Moto7man Pictures & Videos 8 10-28-2017 09:12 AM
Gas Gas Contact Jt 25 95 Restoration And Help Eyetech General Discussions & Announcements 1 03-18-2016 03:33 PM
2001 XC200 Restoration Project Lincolnlock Enduro Engine - 2 stroke 19 04-22-2014 03:42 PM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
