Old 06-26-2020, 06:21 PM
Delphinus Delphinus is offline
Btw should I start with middle clip on the needle?
Old 06-26-2020, 07:40 PM
I'd suggest clip 2. (second from the top)
Old 06-26-2020, 07:58 PM
Gasser Nate's Avatar
Australia post service is an absolute joke. You are better off joining a baseball club, getting some practice in and just throwing your packages. Or training some carrier pigeons.
Old 06-27-2020, 11:40 AM
A stic kit was sent to me from the US from EAGLE RIVER, WI 54521 on May 11th. May 12th it was in Chicago. Since May 16th USPS tells me it is in transit to the next facility, wherever this may be.
Over a month now and no clue where my stuff is.
Old 07-19-2020, 12:21 AM
Finally got round to installing the new needle. Been pouring with rain here recently and too much else to do.
Bike definitely running a whole lot better! What a difference a needle can make! Not as boggy when pulling away from low revs. Doesn't require the throttle held half open to start it after stalling. Easier to ride slow.
If I've been pottering around slowly in 1st, then accelerate hard, it still has a bit of hesitation. Eg accelerates, flattens, then pulls away again. Once you do this once and let it "clear it's throat" it's crisp after that if I repeat the acceleration. How normal is that or can some more tuning improve this?
Tried different airscrew settings. 1.5 out was what I normally used. Didn't notice a lot of difference 2 turns out. Still learning to feel the difference. Even 2.5 turns out I didn't notice an obviously 'lean' condition eg expected revs staying high after blipping throttle.
Old 07-19-2020, 03:32 AM
What's your current setting?
I like to make sure the slide is almost closed. I want my bike to idle in neutral, but the drag of the clutch to be just enough to make it stall.
You'll never find a 'perfect setting'. If you run just right doing loops of the back yard you'll probably find yourself lean when out under some heavy loads. Acknowledge that there will be compromises and then tune for what works best for most of your riding.
Old 07-19-2020, 04:53 AM
(F5)'s Avatar
(F5) (F5) is offline
Just had conversation with a mate we put a new needle in. Out on a road ride, stopped for a pie.
Was super sceptical. Then became a convert
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 07-19-2020, 05:46 AM
Yeah currently in clip 2 as you advised and 1.5 turns out. I'm happy, prefer a tad rich provided it doesn't foul my plugs than too lean, and means I can open it up if need be.
Should I do a plug chop with the new needle setup to check it's not too lean at the top?
And like you say, very very easy to change the needle. Much faster than I expected.
Old 07-19-2020, 02:04 PM
(F5)'s Avatar
Mine wasn't revving out till I went down a main, and then again till it did. But I have reshaped head so result may vary.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 07-21-2020, 05:56 PM
Have a play with your air screw setting. Sounds like its close.
You can do plug chops etc with the main if you'd like. No harm in doing so.
Running rich EC300 swegass Enduro Engine - 2 stroke 15 08-19-2017 08:00 PM
2004 EC200 running rich won't idle malcolml10 Enduro Intake/Carburetion - 2 stroke 7 02-18-2017 11:46 PM
2012 ec300 running bad 1/4 to 1/2 throttle gas-gas 52 Enduro Engine - 2 stroke 6 12-20-2012 10:48 PM
Running rich Evans P Enduro Intake/Carburetion - 2 stroke 2 02-26-2010 12:50 PM
Running rich rustygun Enduro Engine - 2 stroke 4 06-20-2008 04:18 PM
