Go Back   Rieju & GasGas Legacy Riders Club Forum > Community Forums > United Kingdom
Old 02-13-2012, 01:53 PM
wasp4banger wasp4banger is offline
Originally Posted by hannesd View Post
what does this dry ice look like, is it a spray can of is it some solid substance?
Discharge a carbon dioxide fire extinguisher onto a cloth, the CO2 will form dry ice CO2 can only be a gas or a solid, not having a liquid stage in-between.
So in summary it goes .........gas gas = solid, but we all knew that anyway
Gas Gas EC 300 '06
BMW F650
Old 02-21-2012, 07:51 PM
pscook's Avatar
pscook pscook is offline
Popped some dents today. Pipe was pretty well stuffed in one spot, couple of other minor imperfections around the rest of the pipe. Bought a 7/8" and 1 7/8" expansion plug and a long valve stem. Shaved 5mm off the smaller plug and installed the valve stem. Since the plugs were too small I wrapped them with electrical tape, then proceeded to launch them across the garage. Nice dent in the door, no one was hurt. Bodged together a safety wire contraption for the small plug, then went to work. Popped the big plug. Called it a day. Decided that I wasn't going to let a simple inanimate pipe get the better of me, so I made a couple of mechanical brackets to hold the plugs in place, then went to town.
First step was to heat the area to red hot, then inflate pipe to 60 psi. The dent doesn't "pop" so much as "expand" to its original shape, mostly. Worked on some smaller dents, then attacked the large one. I snapped the first pic after realizing "hey, this might work!" Also, I wanted a little legacy (and evidence), you know, just in case. "So, Ma'am, you say he was using a torch to smoke out of a large pipe?"
Anyway, the big dent started to unfold, so I snapped a quick pic. This is about halfway "fixed," still pretty deep.
pscook's Avatar
Default Continued...
Here it is at the end. I wasn't able to get any "in process" pics as I didn't want to interrupt the gas flow and heating process. Came out pretty good-
It started to develop a tiny crack, so I stopped working on the big fella.
Here is another dent, before and after.
All in all, not too bad. I wish that I had MAPP instead of propane, but you do what you can with what you have.
P3carbon fiber pipe guard Gas Gas stock pipe 08-11 REVERUP Enduro Product Reviews 28 12-30-2013 09:05 PM
Key Removal arminhammer Enduro Electrical & Wiring 11 11-07-2011 07:14 PM
Dent Removal PEB Enduro Engine - 2 stroke 7 12-27-2007 09:23 PM
