Old 12-17-2013, 10:32 AM
Dirt leg Dirt leg is offline
Angry 2005 fse 450
Ok so my temp sensor went out and I over heated my bike, I stop the bike once I notice coolant from the over flow. I washed it, started up fine and put it in my garage. I replaced temp sensor today and it will not start, just occasionally back fires.
Old 12-17-2013, 12:54 PM
webmaster's Avatar
webmaster webmaster is offline
Administrator
You will want to check your water pump impeller - it probably "melted"... A machined aluminum replacement with better flow quality is available as a replacement.
Can't help you on the no start issue - in older models, turning off the key for a minute or two would allow the ecu to reset and get around a hard start issue.
I have a 2005 FSE NORTH GA GASGAS Enduro Engine 4 stroke (including EFI & Exhaust) 2 03-07-2011 11:39 AM
2005 ec 125? kneehurts General Discussions & Announcements 2 12-18-2010 12:47 AM
