Old 03-10-2019, 03:08 AM
julian5000 julian5000 is offline
Unhappy 2011 EC250 Won't Start After Rebuild
Hi All
So I've just rebuilt my 2011 EC250. Apart a stubborn gasket supplier who insisted gaskets for 2002 - 2011 are all the same, it all went pretty well.
Until I tried to start it. It's had nearly everything new, crank bearings, seals, conrod, piston, re-coated cylinder etc.
This is what it sounds like when I try to start, just nothing there at all.
https://youtu.be/D5_LoQ485ZM
I also re-did quite a bit of the dogdy wiring, so I was concerned about that, but the spark looks ok:
https://youtu.be/CnPv9xeM_gQ
I haven't touched the carb, it seems to be getting fuel as the plug was wet.
It's been a long day so it's probably something simple, but I can't help thinking it's something deeper that I fecked up..... Spark + Fuel + Compression = Bang Bang right?
Any ideas welcome, thanks in advance.
Old 03-10-2019, 07:22 AM
Zman's Avatar
Zman Zman is offline
1. Do you have a good spark?
2. What is your plug gap?
3. Does it have good compression?
4. Were the crank seals bad before? If the bike had bad crank seals or another air leak it may have been jetted to compensate. If so it could be way rich.
Maybe install a new dry plug and try to start it without the choke?
Old 03-10-2019, 01:20 PM
(F5)'s Avatar
(F5) (F5) is offline
Plug that sparks on the outside doesn't always work under pressure.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 03-10-2019, 02:14 PM
Thanks guys. I tried again this morning with it all dried out, no choke and it fired up. Zman seems you were on the money. Must be too rich now the crank seals are fresh.
Old 03-10-2019, 02:49 PM
barossi73's Avatar
If bike has been down awhile try fresh fuel.
Generous use of oil on reassembly can make the initial starting harder too.
It may respond differently to how much choke it requires,you may have just flooded it whilst clearing out the startup oil.
2013 ec200r
Old 03-10-2019, 05:52 PM
This was my thought. Assembly lube/oil causing some fouling and flooding.
From the video can hear it has good compression, just not firing up. I would have held the throttle open for a bit as well to clear any flooding out.
I rebuilt an engine for (with) a mate once. For whatever reason (I think he forgot to bring the stator side seal).. anyway he took the engine home and just needed to fit the seal and stator. When he finally got it back in the bike it was surging and wouldn't idle well at all. Upon investigation he forgot to put the seal in entirely!! Amazed that it even started.. and lucky that it never seized.
Old 03-10-2019, 06:21 PM
Yeah seems it was just flooded and possibly a bit rich now with the fresh seals. In hindsight things were pretty wet so it makes sense.
Nothing like walking away for a while. Had been a long day putting it back together and making a new loom.
2011 EC250 Clutch Master Cylinder Rebuild Kit sneaky98gt Enduro Chassis & Body 1 01-18-2018 08:02 PM
For Sale: 2011 EC250/300 E-start subframe F_G Parts 0 05-23-2014 08:13 PM
Start up after rebuild cangy United Kingdom 2 03-03-2014 06:40 PM
Start up after rebuild cangy Enduro Engine - 2 stroke 6 03-03-2014 01:58 PM
