Old 06-27-2019, 03:20 PM
adriano.ro adriano.ro is offline
I know how to do it but I don't know how much preload to make on it. I saw somewhere something about filer gage( is the corect name,for tool that mesure thickness?).
I have an annoying flat spot between 25%-55% of throttle. I suspect the power valve preload. Now is ok,no slop or to much freeplay .
Gear ratio is 13-50
Carb: 40p NECW#3 -some riders find this needle too soft on bottom, it can be part of my problem.
Main jet 170.
Old 06-27-2019, 05:22 PM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Gear ratio is 13-50
Main jet 170.
I have been running a 42 pilot jet on my AS2 (2011).
If your pv is close to right, it shouldn't cause a flat spot at 25%-55% throttle. That sounds more like a jetting issue.
Lots of riders really like the NEDW, so I don't think that's the problem. Have you tried the needle clip in the 2nd groove from the top?
That should lean the jetting a bit in the 25%-44% throttle range, and may make a huge difference.
The thickness measurement tool is a "feeler gauge".
Good luck!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 06-27-2019, 11:04 PM
So the next thing to check is power valve preload and shims! Someone is got photo with the pv assembly where I can see the shims?
Next stept is jetting.
Update soon.
Old 06-28-2019, 06:11 AM
barossi73's Avatar
NED_ is half clip richer than NEC_
NEDW #2 = 1/2 clip leaner
NECW #3 (you)
NEDW #3 = 1/2 clip richer
Mines a 200(as2 carb 2screw cap) so diff diameter Nech/Nedh but i found i needed the half clip options to get it dialed that little bit sweeter.
2013 ec200r
Old 06-28-2019, 09:34 AM
Jim Cook's Avatar
Thumbs up
Update soon.
Private message me here and give me your email address, and I will send you a copy of the 2-stroke engine workshop service manual. It is in the pdf format, and I can attach the file to an email.
That will give you photos and procedures for the engine work.
Do you have the parts diagrams? The parts book is available for download; at least those for the newer models are.
https://gasgas.com/us/manuals The operator's manuals are listed as "manuals" and the parts books are listed as "exploded"
.I have most of the older parts books, the ones not included on the web site's list, on my computer at work.
Good Riding!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
'94 Husaberg FE350
'86 Yamaha IT200
Let's go riding!
Old 06-28-2019, 09:56 AM
Good Riding!
Jim
Tnx a lot Jim, I already have parts diagram in PDF format, repair manual is ok but too vague for what I want.
Old 06-29-2019, 12:31 AM
Update:if I adjust pv preload a little bit higher, will not rich full operation,but the bike will rev nice and linear until the power valve start to open.
If I set too soft the preload,will open 90% but with sag on power....
Old 06-29-2019, 12:16 PM
I had mine apart yesterday after not touching it for a few years. I'd already had the preload shims out, this time I ground 0.5mm off of the spring also, incredible improvement.
2016 RM-Z450
Old 06-29-2019, 01:39 PM
What was your symptoms?
My pv spring is red,if the colour means something.
Old 06-29-2019, 01:47 PM
Someone cut a little bit from actuator stop bolt ,with very good power gain.
Low down / tickover issue HELP stevehipkiss Enduro Intake/Carburetion - 2 stroke 9 02-14-2011 09:03 AM
jetting - idle issue. stainlesscycle Enduro Intake/Carburetion - 2 stroke 7 12-30-2009 02:47 AM
clutch issue boostedte37 General Discussions & Announcements 2 11-09-2009 06:58 PM
ec 400 gearbox issue Paul Somerville Enduro Engine 4 stroke (including EFI & Exhaust) 3 09-05-2009 10:17 AM
PowerValve Issue- Take A look at this Picture alexpp Enduro Engine - 2 stroke 13 04-12-2009 12:13 AM
