Old 09-11-2017, 09:19 AM
beenallicanbe beenallicanbe is offline
Default Rekluse Core EXP 2.0 Auto Clutch
Hopefully someone will chime in and give me some guidance. I have a Rekluse Core EXP 2.0 Auto Clutch installed in my 2007 EC 300 and I want to change back to a regular clutch. Can I just install the stock frictions and steels and be good to go or do I need to switch out everything? Any assistance would be much appreciated.
Old 09-12-2017, 03:26 PM
gasser's Avatar
gasser gasser is offline
The Rekulse uses fewer friction and steel plates so you will need 1 or 2 more of each and the original pressure plate. Let me know if you need anything I will have it and I live in Cookeville just over 100 miles west of you. I might be interested in the rekulse if you want to sell it. Ken 931-854-8037
Old 09-12-2017, 06:08 PM
I am taking the rekluse 2.0 plate out Thursday. How much do you think it's worth? I am keeping the cover and getting new friction and steel plates for now to fix my problem.
Old 09-17-2017, 07:25 PM
gasser's Avatar
Does it have the external adjuster that fits on the left side of the bike just in front of the countershaft sprocket? It fits on the slave cylinder that the clutch cable fits into.
Old 10-01-2017, 10:41 PM
Samkjenn's Avatar
Samkjenn Samkjenn is offline
Ok so similar situation as beenallicanbe except I have the core exp 3.0 I have never had a rekluse until I bought my 2011 ec250 second hand and after 15+ hours I can say I’m not digging it. Just wondering on what I need to change back I have all the original clutch parts to return it but what about the adjustable slave can? Does that need to be removed too?
Old 10-02-2017, 01:37 AM
Anders Anders is offline
Originally Posted by Samkjenn View Post
Ok so similar situation as beenallicanbe except I have the core exp 3.0 I have never had a rekluse until I bought my 2011 ec250 second hand and after 15+ hours I can say I?m not digging it. Just wondering on what I need to change back I have all the original clutch parts to return it but what about the adjustable slave can? Does that need to be removed too?
I don't know if it has to, but I would remove it for two reasons:
  1. The Rekluse is useless without it (relevant if you plan to sell the Rekluse)
  2. I cannot see any need for it with a std clutch
Auto clutch Install, Rekluse or S3 Clutch Basket? Moto7man General Discussions & Announcements 49 11-24-2013 12:41 AM
Wanted to buy: Rekluse auto clutch offroadingisbest "Wanted to Buy" & "Want To Trade" 1 11-14-2013 12:00 AM
Rekluse has a new Adjuster for their auto clutch... rgranger Enduro Product Announcements 13 03-05-2013 07:21 AM
