Old 06-01-2010, 10:29 PM
HydroDog's Avatar
HydroDog HydroDog is offline
Default Silencer Grommets
Does anybody have a line on where to buy new grommets for FMF silencers?
Mine are about junk and need replacing. I called FMF and they do not sell them seperate, they only come with a new silencer. I was looking at McMaster-Carr and they do not have any that are a close match.
Any ideas?
07 GG EC 300
05 KTM 250 exc
99 KTM 640 enduro
Old 06-02-2010, 04:43 AM
eff's Avatar
eff eff is offline
Do you mean the tubing where the stinger and pipe meet?
2004 GasGas DE250
Old 06-02-2010, 05:29 AM
eff's Avatar
eff eff is offline
Or, after I thought about it, the mounting grommits?
BE250026005 - 15-SILENTBLOCK SILENCER
From your dealer.
2004 GasGas DE250
Old 06-02-2010, 07:08 AM
Rick's Avatar
Rick Rick is offline
I second the OEM stuff, I had to replace my for my TCII, also use OEM.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 06-02-2010, 08:34 AM
eff I believe he is talking about the rubber grommets that you put the bolt through to mount the silencer to the subframe
I got a bigger problem ...
my grommets are fine ... but the hole they go into has worn into a bigger size so now the grommets roll around inside the hole and the pipe fits kind of loose, I don't see this getting anything but worse. Only solution is a new silencer or alu welding and machining new holes. which would probably cost the same as a new silencer ...
Old 06-02-2010, 11:36 AM
flybars flybars is offline
Could someone take a pic of this? I'm not sure if I understand, but sounds important.
'14 Beta 300rr
'05 GG DE300
'03 GG EC250
'01 XR440
'09 FZ1
Old 06-02-2010, 05:50 PM
HydroDog's Avatar
Thanks for tip and the part#
I guess I should have made it a little more clear.
I was talking about the mounting grommets. I have the same problem also of the mounting holes being worn out on the silencer but I was going to weld them up and machine them back to size.
07 GG EC 300
05 KTM 250 exc
99 KTM 640 enduro
200 Vs 250 silencer / end can iancp5 Enduro Engine - 2 stroke 1 06-04-2009 02:41 AM
MC Silencer on ab EC 250 '08 GG27 Enduro Engine - 2 stroke 3 03-31-2008 11:16 AM
Side panel mounting screws & grommets: 07 EC 300 Gregarious Enduro Chassis & Body 2 02-19-2008 07:07 PM
