Old 10-24-2010, 08:39 AM
Klausen Klausen is offline
Default Speedo problem on my Gasser
I have seen that the thin cable (labeled with power) on the little white connector (one of the 4) was broken.
After this connector is a little circuit protected from black heat shrink tube and then a bigger connector.
Now I sold the thin cables (red & white) with the thicker cables from the circuit directly (black & red) I believe.
The problem:
When I start the bike every segment on the speedo become black.
After pressing the button in the middle everything is fine except all data are delete.
When I stop the bike the clock is running!!
What is the problem.
Husqvarna TE 300
Old 10-25-2010, 11:53 AM
Now the speedo says nothing.
I believe the lithium battery is empty.
Husqvarna TE 300
Old 12-04-2010, 09:40 AM
wasp4banger wasp4banger is offline
Question Speedo wiring
Klausen
On my 06 EC300, the short piece of wiring you mention between the speedo unit and the loom has a diode and capacitor included within the heatshrink wrap.
I think that this acts as a crude rectifier to feed DC to the speedo instead of AC.
Mine keeps blowing the capacitor as the revs peak out. The capacitor is a 100microfarad 35volt and the diode not sure, maybe a zener diode?
If you have done away with this wiring link then I think you'll be feeding AC to the speedo?
Anyone know if there is a voltage regulator and if so where it is located on the bike and what readings it should give
Old 03-08-2011, 01:24 PM
vgstef vgstef is offline
Default capacitor
can you buy this piece of wire with the capacitor ? I am having the same problem when the idles goes to low i am loosing the sreww and they only way it is coming back to life and to close all the light .
Old 03-08-2011, 01:27 PM
Default picture
thsi is the wire that goesto the speedo I have a ec 300 2006
Old 03-08-2011, 02:01 PM
vgsef
Can you tell us what it says on the diode / zener diode?
Mine blew both the diode and capacitor when the wires shorted out, insulation on wires broke down. Capacitor is easy to find replacement, but as the diode blew, don't know what to put back to replace it?
Yes this converts ac to dc as a half wave rectifier.
If you connect a 9v battery (pp9) to the spare wires you can make the clock hold its memory. Mine loses the time after about a minute of killing the motor.
Gas Gas EC 300 '06
BMW F650
Old 03-08-2011, 06:32 PM
Originally Posted by wasp4banger View Post
vgsef
What i can see on the diode is : IN40007
HY
Old 03-08-2011, 06:34 PM
Klausen
I just change the capacitor with a 50 Volt , 220 u .I did a test and it is working fine, will see how long that will last. My diode was fine .
Stephane
Old 03-19-2011, 03:21 PM
06EC300 06EC300 is offline
The gauges on my 06 EC300 have stopped working...this diode stuff might be my issue was well.
ec 250 speedo help gregtenerife Enduro Electrical & Wiring 3 06-17-2010 01:06 PM
2004 EC200 Speedo Problem warnzie Enduro Electrical & Wiring 1 10-29-2007 06:29 AM
Speedo on EC300 07’ Larsa General Discussions & Announcements 6 10-27-2007 08:19 AM
EC 300 speedo ?? oldgoat Enduro Electrical & Wiring 7 08-11-2007 03:29 AM
