Old 02-13-2008, 12:02 PM
ScottyR ScottyR is offline
Junior Member
FYI, I just installed a Utah Cycle Skid Plate on an 07 EC300 and it fit just fine. I wouldnt hesitate to use this plate again.
Old 02-13-2008, 01:38 PM
Rick's Avatar
Rick Rick is offline
I have no problem with the Utah Cycle Sport skid plate. I've had one on my 99 since I got the bike. I did however silicone 2 strips of 1/2 foam insluation to the skid plate under the frame tubes. I noticed that cut down on engine / frame noise. Replacement frame clips / bolts can be had through Moose.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 02-14-2008, 07:21 PM
REVERUP's Avatar
REVERUP REVERUP is offline
Any feed back on how any of, or all of these brands of aluminum skid plates are attached.
That is my biggest concern, as the crd was just attached by 2 points the front and the back. The back mount being a part of the skid plate and bent toward the front of the machine and hooked over the frame cross member. Which in turn if your going forward witch most do on a motorcycle, and you hit the plate and the front aluminum T style mount isn't able to withstand the impact the back one does nothing to help the front mount it just slides off the bike and wallah there goes your $100 pretzel. Stupid design IMO.
The way I hit G outs and case it repeatedly I need multiple attaching points like the frame spars too. I am really rough on skid plates.
A few of my buddies often comment about it and tell story's of how they were chasing me and next thing they know my skid plate is flying back at them, as if my roost wasn't enough.
Any info would be appreciated as I will be in the market for one in the next week or so for my new 08.
Huge thanks: GAS GAS OFFROAD US, Skagit Powersports, Cycle Gear, LTRacing, Scorpion Racing, users of GasGasrider.org, and CFMC!
Old 02-15-2008, 08:10 AM
gasIdaho gasIdaho is offline
The newer CRD plates have the rear tab pointing backwards so the slide off issue is allieveated. I like mine OK. I didn't know Utah CS made one for the gassers....they're stuff looks nice. You'll want to make sure and cushion your frame tubes between the plate otherwise you'll get some horrible vibration/noise.
Old 02-15-2008, 02:38 PM
Rick's Avatar
The Utah Sport has 3 attachments, 2 in the front and 1 in the rear of the plate. Mine has taken some pretty hard abuse and has never came off or came loose for that matter.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 02-15-2008, 05:20 PM
PEB PEB is offline
I got my Hyde combo today. It looks like it mounts to the frame in the front with a double c clamp, in the back with two c clamps and to the pipe with two hose clamps. All the hardware looks to be stainless and it came with closed cell foam to stuff the nooks and crannies with, nice details I thought. Can't wait to put it on!
Paul B
Old 02-15-2008, 06:40 PM
GMP's Avatar
GMP GMP is offline
Paul,
I wonder if you got new mounts. Post a photo of the mounts if you have time. I just made a new front T Bar mount. The problem is that the cases are close to the frame in the area that the front mount must fit, so you have to use the thin stainless, I just backed it up with thicker aluminum etween the tubes.
Old 02-15-2008, 07:51 PM
PEB PEB is offline
Here are some pics of the mounts and one of the bore waiting for some fresh action.
Old 02-15-2008, 08:05 PM
GMP's Avatar
GMP GMP is offline
Looks like you got both old and new mounts! I didn't get the single curve type clamps, just the double and the single angle ones.
Old 03-04-2008, 06:27 AM
rpduc rpduc is offline
Is the Hyde Combo unit available (or will it fit) '05 and older 250 ecs and mcs? I don't see anything but '06 and '07 listed on the Hyde site.
And another newbie question... These bikes I just picked up all have FMF fatty pipes. I assume these were aftermarket so how does that affect fitment/availability when considering a skidplate/pipe guard combo?
EC Skid Plate cdn280 Enduro Product Reviews 32 10-15-2010 04:22 PM
06 300 skid plate on a 10 Diddel General Discussions & Announcements 1 06-09-2010 04:28 AM
Ricochet Skid Plate gasIdaho Enduro Product Reviews 11 08-27-2009 02:46 AM
skid plate & rad frames motodave63 Enduro Product Announcements 2 05-02-2009 10:37 AM
Hyde skid plate killergasser Enduro Product Announcements 40 06-07-2007 08:20 PM
