Old 09-03-2008, 08:26 AM
Eric K Eric K is offline
Originally Posted by Nick View Post
The armorall is probably letting the tube slide inside the tire as there is no friction to hold it in place. I've seen tubes that stretched by a couple inches in lengh inside of a tire. Ditch the lube.
I second that. Armorall is great if you want you tube to slip all over the place.
I have run Moose HD tubes as low as 5 psi with no slip inside the Mitas trials tires. I do not use any armorall, baby powder, etc.
I use Talon rim locks as I have had pinch falts caused by the sharp edges of the motion pro rimlocks.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 09-03-2008, 12:40 PM
svt2224 svt2224 is offline
Thanks guys, I'll pull the tube and clean it and the tire. As far as the locks I ground them down on the edges, hopefully that will ward off pinch flats.
J
Old 09-04-2008, 05:02 PM
Loosenut's Avatar
Loosenut Loosenut is offline
Hold on a minute. I have used Armour All on every tube I have installed for about 7 or 8 years now. I coat the entire tube and the inside of the tire carcuss. My tubes last longer and they are near impossible to pinch. I have had one pinch since then and it was a doozy that I was lucky to walk away from. The talc people use is for lubrication. I run Dunlop 756's, as the trials tire and I don't get along so well on the 300s.
My valve stems are sitting at about 80 - 85 degrees after riding.
FYI, I am still using the stock tubes and rim locks on my '05 EC300.
Mike Baxter
2005 GasGas EC300 (Ohlins front and rear)
2007 Yamaha FZ1
2003 Pampera 280(hers)
Old 09-05-2008, 08:03 AM
iancp5's Avatar
iancp5 iancp5 is offline
Originally Posted by eff View Post
Try running more than 8 psi. My guess is that the tube is rotating inside the tire.
That would be my bet - had it happen to me. Heavy tubes will spin under braking when you lock the rear wheel suddenly. Don't run HD MX tubes in low pressure trials tyres. At low pressure the weight will spin the tube and rip the valve. Make sure the tyre & tube are clean unusually you want as much friction between tube and tyre as possible. You could try looking for a bigger tube. The dilemma is that running more pressure negates the point in running a trials tyre. I found with a standard, lightweight 140/80 x 18 tube they are fine at 8 psi but go lower or use a heavy tube and they turn under sudden lock up braking. If you want to run lower, which I have you either need a bigger tube or maybe avoid the rear brake at speed on slippery ground.
Old 09-05-2008, 01:53 PM
Thanks for all the info guys. As a last ditch effort I am going to try a larger std. thickness tube with no lube. Maybe that will work out, if not I'll go up a few #'s.
J
Old 09-05-2008, 02:04 PM
JoshP's Avatar
JoshP JoshP is offline
I used to get the Michelin heavy duties, but I don't think they make those anymore. I have since switched to this one it's only $19.00 on RockyMountainATV.COM "Bridgestone Ultra Heavy Duty Motorcycle Tube". Probably have about 2 years on my current rear tube with typically 2 days a week / 12 month riding schedule (Just got my new trelle front I'm stoked for snow! ). So it's alot of tube with no pinches or stem breaks and my stem will be at a total 65 degree angle after riding. Sometimes I don't even fix it and ride like that for a month before I change out my tires. No lube, no powder and no complaints. Oh yeah and we run 8 to 10 PSI, I typically run 10 but have run 8 with no issues but slams too much as the tire degrades.
Old 09-05-2008, 04:22 PM
gasser's Avatar
gasser gasser is offline
Smile
I used to have the same problem on my 250 and 300 but much less so on my 200 due to less power. What's happening is the trials tires can flex by more than an inch (I've actually got pictures of this somewhere) so those heavier tubes that don't stretch as much as the thinner ones will jerk the stem out when they move with the tire. I had absolutely no luck using extra baby powder, rim locks (tried two), or wd40. My problem completely stopped when I went back to a standard weight tube. - Ken
Old 10-11-2008, 04:35 PM
Ken,
The std. weight tube fixed the problem. No problems with flats, so far it has made it trough 100mi of Arkansas rocks and 30mi of sand and hardpack.
Thanks guys
J
Old 10-12-2008, 07:36 AM
fury1's Avatar
fury1 fury1 is offline
I just went back to my trials tire that had been on the shelf for two or three years,forgot how much fun and what a cheater this tire is,got it about 12PSI and havent had any issues running a H/D tube,we have had a serious mud race where most didnt finish the race,eight guys finished the course,I finished 9th O/A but houred out at the last check,then I took it to NY where it was mostly hills and off camber stuff and the bike shined everywhere,no disadvantages anywhere,been practicing hard with it lately as we have four more runs till the end of the season and I like sitting in first in class! trying to get crem55 to make the switch,but without some practice time he might not be able to adjust to the different riding style in time before the next few races
Old 10-12-2008, 07:50 PM
I just switched from an Irc back to a 756. The irc had plenty of life left on it but I wanted to see what a knobby in the back would be like ... I ran the irc at 12psi w/one mp rim lock and b stone uhd tubes. I had no issues with tube movement and I ride nasty rooty rocky stuff. after I burn through the 756 I'm going to put a d lop 803 on the back. Cheater tire is right!! Trials tires kick butt!!
G2 throttle tube iancp5 Enduro Product Reviews 52 08-25-2014 10:41 PM
Trail tech troubles skid jackson General Discussions & Announcements 8 06-02-2010 07:15 PM
Dunlop 803 troubles keeping it on kendunn Enduro Chassis & Body 15 04-22-2010 04:50 PM
troubles with.....something? kendunn Enduro Intake/Carburetion - 2 stroke 6 10-16-2009 08:48 AM
300ec 2001 Engine Troubles toka2020 General Discussions & Announcements 1 06-05-2008 03:46 PM
