Old 05-17-2018, 03:03 PM
taylor146 taylor146 is offline
Default 18 ec300 jetting
Hi all,
Since I've had the latest ignition map the NEDW needle I was using that seemed slightly rich now seems a bit lean up to 1/4 throttle. Would like to know what needle to use , was considering trying the standard needle again. Maybe NEDH?
Thanks
Darren
Old 05-18-2018, 01:25 AM
fred99999au fred99999au is online now
I have a Suzuki NECJ in my 18 GP300. Dunno if that helps due to the different head or not.
Need to find a table of needle specs to work out if it is richer or leaner.
Old 05-18-2018, 03:44 AM
J diameter is leaner than W. Going to a H may help with your issue, or bumping the pilot up a size might too.
What clip position are you in? Have you tried going richer?
Old 05-18-2018, 04:21 AM
If its lean up to 1/4 changing the needle wouldnt change that. You can try to close the air screw 1/4 turn wise or take next bigger pilot jet as Jakobi suggested.
Old 05-18-2018, 03:40 PM
Gottsell Gottsell is offline
I have the same problem with my std ec300. It work fine before the new mapping. Now i cant get it right. Either it goes very rich or When it goes fine it is detonation
Old 05-18-2018, 08:27 PM
Motocrotts's Avatar
Motocrotts Motocrotts is offline
With the new mapping I'm running the standard needle in the 2nd pos, 170MJ and 40PJ. 2500' and 60 - 80 degs F.
Old 05-19-2018, 03:13 AM
Hi all thanks for your replies.
Had an interesting conversation with a guy here in the UK who looks after the team bikes for gasgas uk. He said they also tried all sorts of different needle's before the map update , but now runs the standard needle and says it's spot on. He said they have been feeding some input back to the factory and from what he's heard they have advanced the ignition curve down low and retarded it further up . So will give the standard needle a try again and see how it is.
Old 05-20-2018, 10:48 PM
chunkysoup's Avatar
chunkysoup chunkysoup is offline
I went back to the stock needle after the remap and it ran way better.
2018 GASGAS 300XC
2011 GASGAS 300EC
1981 CR250r
1999 Excelsior Henderson Super X
2003 FZ1
Old 05-21-2018, 02:04 AM
What is the stock needle?
Old 05-21-2018, 09:46 AM
chunkysoup's Avatar
The one that came in the bike from the factory the N1EF needle
2018 GASGAS 300XC
2011 GASGAS 300EC
1981 CR250r
2003 FZ1
New to me 04 ec300...jetting help 04gasgas Enduro Intake/Carburetion - 2 stroke 10 02-12-2011 05:08 PM
ec300 jetting Steve ROC Enduro Intake/Carburetion - 2 stroke 4 04-26-2010 08:49 PM
ec300 jetting moff747 Enduro Intake/Carburetion - 2 stroke 8 01-08-2008 03:21 PM
LTR jetting kit for an '03 EC300 WoodsRider Enduro Intake/Carburetion - 2 stroke 1 05-24-2007 10:09 AM
04 EC300 jetting? DWreck Enduro Intake/Carburetion - 2 stroke 13 11-26-2006 08:12 PM
