Old 08-25-2007, 03:19 PM
Default How to set float level. Revisited.
A while back, I posted a link on how to set your float level.
I finally found it after a long search.
Here it is again for those that need to have their's reset..
http://www.dirtridersinternational.c...?TOPIC_ID=2292
Old 02-07-2008, 09:01 PM
For some reason the photos won't come up.
Here they are in the order that they appear in the instructions.
(Float assembly pivot pin not shown.)
(Fuel inlet needle shown with Viton (rubber) tip. The Viton is used to isolate the fuel inlet needle from vibration and to create a better seal against the fuel inlet valve seat.)
Old 04-24-2008, 11:15 AM
jyellard jyellard is offline
The first link no longer works.
I have checked and adjusted float level on other carbs, so could someone post some basic instructions with dimensions?
Thanks,
Josh
Old 07-08-2008, 07:58 AM
stay_upright's Avatar
Try this http://www.keihin-us.com/am/_media/pdf/slide_valve.pdf
Float height is mentioned on the right.
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
Old 04-11-2009, 11:12 PM
Treesmacker Treesmacker is offline
Thanks,
Josh
The float Height should be 16mm from the bowl mounting face to the top
of the float as shown in the picture.
Old 04-28-2010, 11:42 AM
ec300 dave ec300 dave is offline
Default help on float height
Hi can anyone advise me on the correct float height for my year 2000 ec 300.
Old 04-28-2010, 03:59 PM
stainlesscycle's Avatar
16mm to the best of my knowledge.
07 ec300
www.stainlesscycle.com
Old 05-17-2014, 10:56 AM
liv2day's Avatar
liv2day liv2day is offline
Hey guys, any chance someone has pics showing this? None of the links work and the old pics are no longer there. Need some help as the 250 is pissing fuel out the vent tube when the fuel is on.
Not sure where to measure float height from?
Old 05-17-2014, 03:29 PM
External Link
If the level is right and its still overflowing double check the viton tip on the float needle. Sometimes they perish, othertimes they just have a bit of grit stopping it from sealing.
Old 05-17-2014, 05:29 PM
Buysomerice's Avatar
Buysomerice Buysomerice is offline
I just fixed the float level on a kdx last week where the factory specs werent right for that carb because the needle valve seat needed to be altered. Long story short I made a fuel level guage out of tubing and a stopper. The gas goes up the tube to about 2 mm below the mating seam of the carb bowl.
EC300 Idle Revisited. Ud_luz Enduro Intake/Carburetion - 2 stroke 35 01-07-2011 07:39 PM
Rear wheel spacers revisited. Ud_luz Enduro Chassis & Body 9 09-13-2010 08:01 PM
Zokes oil level? jostby Enduro Suspension 2 06-20-2009 11:29 AM
Fork oil level ? Brian VT Enduro Suspension 4 03-10-2009 08:57 PM
WP Fork Oil Level MattR Enduro Suspension 11 08-02-2006 10:40 AM
