Old 05-28-2018, 03:27 AM
Default PV adjustment GG300GP
Sorry for all the questions, being new to GG and coming from over 10 years of orange some things are a bit odd for me.
Basically I know what PV's are doing but the owners manual is a bit meager.
I am used to chug the bike uphill, lets say in second gear and then whack the throttle to get over logs and stuff. The Kato didnt need clutch help, even when the rpm was low the engine picked up very aggressive.
With the Gasser I struggle as power/torque comes too slow. I think it must be possible to make the motor more aggressive down low to mid but have no clue how to turn the adjuster screw.
Anyone else had a similar problem or prefers an aggressive engine?
Old 05-28-2018, 01:54 PM
Change the needle first. Really.
You'll be boring your mates how two visually identical bits of wire changed the bike.
Old 05-29-2018, 11:50 PM
Thx F5, I 've ordered a JD kit.
Only surprise is that JD recommends a 178 main jet
Old 05-30-2018, 01:59 PM
The tail end of the needle can affect the flow rate of the main to some extent. Have no experience of JD.
Old 05-30-2018, 04:11 PM
The JD needles are pretty thick. Even putting a Soozi NE next to a N3 you can easily see the difference with the naked eye.
Old 06-02-2018, 12:46 AM
I have installed the JD kit and as you say the needles are thicker than the OEM ones. Instead of the 178 main there was a 176 in the kit which I installed. I e-mailed them if thats either a printing error -it says install the 178 included in the kit- or a wrong main jet has been packed.
Instead of the required 42 pilot jet I put the 40 in, and the bike runs well with it. Low down burble is almost gone and the idle is stable although it is very low (as I prefer it).
But I have massive other problems with it, but will open an own thread soon. Gotta run now...
Doc
Squish adjustment Marcão Enduro Engine - 2 stroke 20 07-12-2012 09:37 PM
Idle adjustment help FSR 450 chuck Enduro Engine 4 stroke (including EFI & Exhaust) 1 06-10-2012 10:11 AM
CluTch adjustment Rabbitist General Discussions & Announcements 5 08-30-2011 09:29 AM
rekluse adjustment merlot General Discussions & Announcements 3 10-20-2009 03:32 AM
Clutch adjustment? Arkangel Enduro Engine - 2 stroke 26 04-08-2009 09:37 AM
