Old 02-09-2012, 08:50 PM
Scar13 Scar13 is offline
Default High pitch Squealing from exhaust and exhaust flange?????
Afternoon everyone,
My 2010 ec 250 once it warms up has a HIGH pitch SQUEAL coming from the exhaust and exhaust flange... I know it comes from here because I took the Exhaust pipe off and notice it had O rings around the Flange.. SO I went to autozone and bought some new oRings and put them on.. Now the sound is def gone, but I have to wonder how long O Rings will last in that type of situation with the vibrations and heat... My bike has maybe 15 hours on it and they wore out QUICK!!
Is anyone else having this issue????
Also anyone else notice your flange gasket leaking at the bottom???
Thank you all in advance!!
Old 02-09-2012, 09:19 PM
The O-rings do blow out and will cause the noise you speak of. Metal on metal vibrating = high pitch. When replacing the O-rings pick up a set of Viton ones. They will handle the temps better than rubber. I have also had good results using a high temp silicone gasket sealer in addition to the O-rings. Other than that make sure the pipe is aligned properly.
Some have used a slightly thicker O-ring which makes it a bit harder to get the pipe on and off but provides a nice stable seal once on.
When the o-rings wear out the spooge will leak from the bottom and vibrations/noises will occur. Mine are mostly on decel.
Old 02-09-2012, 10:05 PM
Jakobi,
What size vitron O rings are you using?? What is the Thinker size??
Are you ordering online or getting from a local supplier??
Decel?? Decline?
Thank you greatly for your time and reply!
Old 02-09-2012, 11:20 PM
Originally Posted by Scar13 View Post
Jakobi,
Decel?? Decline?
I use the stock 44mm ID, 3mm width
Thicker size as in 4mm width just to assist sealing.
I buy mine from the local bearing shop.
Decel as in deceleration. As the engine rmp are falling is when the noise is most present.
Old 02-10-2012, 09:13 AM
Banned
here is a link to hi-temp viton o-rings. 10 for $15 They are 44mm id x 3mm wide.
http://www.mcmaster.com/#o-rings/=f60v14
Old 02-11-2012, 11:32 AM
Eric K Eric K is offline
I use 43 x 3.5 Viton o-rings. They are difficult to install, but seal much better and last longer.
Here is what works best to install...
Put the o-rings in the groove dry. Then grease the inside of the pipe flange and the outside mating surface of the o-ring.
Push the pipe on as far as you can. Most likely it won't readily go on all the way.
Then hook up the springs and let the springs pull the pipe on. You may need to push some for final fit.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Which Exhaust? Pepperami Enduro Engine - 2 stroke 7 11-13-2011 09:15 PM
FMF exhaust gevandam Enduro Engine 4 stroke (including EFI & Exhaust) 0 04-28-2009 02:48 PM
09 125 Exhaust? hasslbri Enduro Engine - 2 stroke 2 01-28-2009 11:59 AM
EC 300 Exhaust dB jyellard Enduro Engine - 2 stroke 7 09-18-2008 08:30 AM
