Old 06-06-2020, 04:09 AM
RudolfHucker's Avatar
RudolfHucker RudolfHucker is offline
Put it back how it was and leave it alone.
Old 06-07-2020, 06:00 PM
gasser's Avatar
gasser gasser is offline
Originally Posted by Gasser Nate View Post
Spark at the right time? Wondering if a keyway got sheared possibly trying to turn the motor over when it had water in it. Hydraulic locks can do a lot of damage.
You nailed it. It was probably 50 degrees out of time. Runs great now the head cleared up the bottom end power and it's stronger in the midrange as well - very happy with the RK head.
Old 06-08-2020, 12:37 AM
Gasser Nate's Avatar
Sweet! Gotta love a easy fix. Not much can stop a Gasser from running. 💪
Old 06-08-2020, 07:08 PM
Sweet! Gotta love a easy fix. Not much can stop a Gasser from running. ��
You think this might be another case of the nut not being torqued down properly?
I suspect I should take the time to remove mine and reassemble with Loctite.
Old 06-08-2020, 07:32 PM
(F5)'s Avatar
(F5) (F5) is offline
Don't put Loctite on the taper mind. The nut sure as I think you meant. .
On older bikes I relap the taper with a small amount of valve lapping paste (stuff knows why I have any, I've had it since the 80s before I was enlightened). And carefully clean any traces from the keyway.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 06-08-2020, 07:43 PM
Very good chance of it matey! Yep get right on it bud, do the wet mod while you are in there. Stop being a lazy bugger!
2017 ec250 to a 300 cylinder and head swap wit terrible rattling noise mvrider2 Enduro Engine - 2 stroke 2 03-02-2020 09:05 AM
I put my first mile on my yz250f 300 gasgas swap bike!!! Kbowen4 Enduro Chassis & Body 20 03-10-2017 08:50 AM
Seal head swap? Ohlins rear shock Gass Enduro Suspension 4 08-17-2016 02:32 AM
Three Year Head Start -- Parting out in 2018 AZRickD Parts 2 07-10-2015 09:49 AM
